Club Lexus Vendor Marketplace The place to find group buys and great deals from ClubLexus' supporting vendors.
** GB ** Air Force Coilover/Air Suspension Kit **
Old 01-23-08, 09:14 AM
Carson-Lex
Original CL Sponsor since 1999
Carson-Lex's Avatar
Default ** GB ** Air Force Coilover/Air Suspension Kit **
Alright CL members,
We have ironed out all the details and have this GB ready to go, so here goes. Please see below the pictures for specs and technical info. As always, please feel free to call or email with any questions.
Kits are available for the following vehicles
IS 200 / IS 300 / GS 300 98~05 / GS 400 98~05 / SC 300 92~99 / SC 400 92~99 / GS 300 93~97 / SC 430 00~UP / LS 400 94~00 / LS430 01-06 / IS 250 06~UP / IS 350 06~UP / GS 300 /GS 350 06~UP / GS 430
Air Force Coilover/Air Suspension Kit.
GB price will be $2770.00 Shipped (lower 48 states)
retail is $2995.00
Please Use GB Code CLGBAF
Order HERE
Remote Pics
Remote Comparison to OE Key Fob
Lowered
Raised
The kit comes with a 1 YR warranty, like any other aftermarket coilover set-up. The contents of the kit include
4 x coilover + camber plate
4 x air cylinder cups (pre assembled-ready to install)
1 x pack of the hose connector
1 x custom made box with air tank and compressor pre-mounted in it ( as you see in the pic)
hoses you need for the car
wire kit to wire battery
The cars and spring rates that each kit come with are as follows
APPLICATION YEAR FRONT SPRING REAR SPRING
IS 200 12 kg/mm 6 kg/mm
IS 300 13 kg/mm 6kg/mm
GS 300 98~05 17 kg/mm 7.2kg/mm
GS 400 98~05 21 kg/mm 7.2kg/mm
SC 300 92~99 17 kg/mm 7.2kg/mm
SC 400 92~99 21kg/mm 7.2kg/mm
GS 300 93~97 17kg/mm 7.2kg/mm
SC 430 00~UP 21kg/mm 7.2kg/mm
LS 400 94~00 21kg/mm 7.2kg/mm
LS430 01-06 21kg/mm 7.2 kg/mm
IS 250 06~UP 12kg/mm 7.2kg/mm
IS 350 06~UP 13kg/mm 7.2kg/mm
GS 300/GS 350 06~UP 14kg/mm 7.2kg/mm
GS 430 06~UP 17kg/mm 7.2kg/mm
Also of note is the following
The air tube included in the kit is 15m long
and the wire is 5m long
Custom spring rates available are from 3 ~ 22 KG-MM
Coilover and cylinder/uppper mount's are made out of 6061 Aluminum. This company is currently working on a kit for the AWD model IS as well.
Old 01-23-08, 09:24 AM
carlos
carlos's Avatar
Do they have a website? What is used for the controls (switches, remote, etc.)? Are the coil overs made by Air Force or are they re-branded? How much adjustment is there as far is height is concerned?
Old 01-23-08, 09:38 AM
javyLSU
2IS OG
javyLSU's Avatar
WOW, what a price!!! Hmm, must...keep...money...in...wallet...
Javier
Old 01-23-08, 09:43 AM
keng714
keng714's Avatar
When will the Gb be ending?
Old 01-23-08, 10:09 AM
ACleanSC4
ACleanSC4's Avatar
INteresting...
Old 01-23-08, 11:36 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
damnit why dont they have anything for UCF2x LS
Old 01-23-08, 01:16 PM
kit cat
kit cat's Avatar
what kind of coilover is it? I hope it's not another restamped ebay coilover.
Old 01-23-08, 01:39 PM
DangGS3
DangGS3's Avatar
if i only had the money =[
Old 01-23-08, 03:32 PM
reamemiya
reamemiya's Avatar
Yes, more backround information please.
Old 01-23-08, 04:41 PM
Carson-Lex
Carson-Lex's Avatar
The coilovers are manufactured by a major company that makes these parts for other name brand JDM coilover suspensions. As many of you know, a lot of different companies sometimes have the parts made by one manufacturer, then the vendors paint and stamp them as thier own brand. This is the case with thei coilover, the manufactures supplies these not only to AirForce, but to other major name brand JDM companies.
I also just found out that it comes with a remote transmitter that allows you to raise or lower the car from outside the vehicle at a touch of the button. I will have pics up of it by tommorrow.
Old 01-23-08, 04:45 PM
chrispy
chrispy's Avatar
I'd be interested depending on what kind of coilover it is. Does it come with a controller?
edit: Just refreshed and saw the new info. Does the camber adjustment also work on the 2GS? And are the "lowered" pictures all the way down?
Old 01-23-08, 05:50 PM
anotherLS
anotherLS's Avatar
you failed to read bro! 94-2000 LS
Old 01-23-08, 06:04 PM
bluerex
bluerex's Avatar
do you have pics for how low it goes on a ls430? i'm interested.
Old 01-23-08, 06:19 PM
The Godfather
The Godfather's Avatar
When is the GB ending? I'll have to come up with some cash but it's gonna take a little while
Old 01-23-08, 06:37 PM
garbage85
garbage85's Avatar
Im sooo in, give me a week
Quick Reply: ** GB ** Air Force Coilover/Air Suspension Kit **
