Adjustable Rear Rca For Gs
by putting it on, it effectively drop your car by xxx amount without affecting the suspension travel and also the camber. so for example if using coilovers you drop the car by 2 inches, making your camber -ve 2 degrees. using this block, maybe you will only need to adjust the coilover 1 inch to achieve the same drop, and your camber might now be at -ve 1.2 degrees
i hope i got this one right, please correct me
uhh i need some camber adjustment for the front. but the site says that i have to have coilovers. but i have springs and my tires are camber'ing real bad. i have like 60% left and the inner edge is bald to the wires.
Not good. What the front RCAs do is lower the car manipulating other parts of the suspension so you wouldn't have to have the car as low with the coilovers. So you would have to raise the car an inch (with the coilovers) then add the front RCA so it can drop the car an inch.
LexFather
Suspension and Brakes
15
06-15-05 12:12 AM
