Stanley Distribution is proud to offer NIC's Cerakote line of thermal coatings
Former Sponsor - Cancelled
Stanley Distribution is now offering NIC industries Cerakote line of thermal coatings. This includes dry film lubricants, thermal Barrier coatings, Heat dissipation coatings, and ceramic coatings.
Dry film lubricants coatings are designed to create a permanent lubricated surface to impede galling and the seizing of components. Like or dissimilar materials can benefit from the application of these materials. The suggested application processes allow the coating to become an intrinsic part of the component rather than a coating on the surface.
Uses:
* Piston Skirts
* Cylinder Walls
* Crankshafts & Camshafts
* Bearings and Gears
* Valve Stems & Rocket Pivots
CerakoteTM Thermal Barrier products significantly reduce heat transfer of components that operate at elevated temperatures. These coatings are used extensively in the automotive, commercial truck, heavy equipment and performance racing industries. Thermal barrier products increase performance, reduce maintenance cost and protect against corrosion .
CerakoteTM Thermal Barrier products can alter heat transfer by up to 15% depending on the specific application.
Uses:
* Piston Domes
* Combustion Chambers
* Valve Faces
* Exhaust Systems and Components
Heat dissipation coating: when applied to surfaces, Micro Dyne's heat dissipation coatings transfer heat away from a substrate, resulting in improved efficiencies, performance and longevity of the coated parts. This ceramic bonded, thermal-conductive coating also helps to prevent corrosion and damage related to chemical and solvent attack. The Micro Dyne Artic Black and Transfer Black coating systems are used extensively in the transportation and electronics industries to reduce residual heat from components.
uses:
* Radiators
* Brake Drums
* Oil Coolers
* Differentials
* Transmission Cases
* Lighting Equipment
* Heat Exchangers
* Transmission Coolers
* Air Conditioning Condensers
Prices:
Pistons
V-136 PISTON COAT on Dome and C-110 MICRO SLICK DF-2 on Skirt ......................................................................... ................ $35 each
Dome Only with V-136 PISTON COAT .. ................... $30.00 each
Skirt Only with C-110 MICRO SLICK DF-2 ............ . $15.00 each
Diesel (4.5 diameter and above) V-136 PISTON COAT and C-110 MICRO SLICK DF-2 .......... $60.00 each
Calipers C-187 TRANSFER BLACK Outside ........ $75.00 each
* cannot be applied to Powder Coated Parts
Calipers C-187 TRANSFER BLACK Outside,
thermal barrier ceramic on piston faces ........ $100.00 each
Pads BLACK Ceramic on Pad Back ......... $15.00 each
Extra Pistons TBC Ceramic ............. $18.00 each
Rotors C-187 TRANSFER BLACK on every thing but
friction surface ......... $100.00 each
intercoolers C-187 TRANSFER BLACK Heat Radiating . $125 - 225
Uses:
* Piston Skirts
* Cylinder Walls
Uses:
* Piston Domes
* Valve Faces
uses:
* Radiators
* Brake Drums
* Oil Coolers
* Differentials
* Heat Exchangers
Prices:
Pistons
JDMmuscle
Performance & Maintenance
01-06-08 09:10 AM
