Mothers PowerBall 4Lights Headlight Restoration Kit At ProperAutoCare.com
Mothers PowerBall 4Lights Headlight Restoration Kit has everything you need to restore, maintain, and protect the look of your headlight lenses and taillight lenses and reflectors. Mothers PowerBall 4Lights Headlight Restoration Kit also works on other clear, uncoated plastic surfaces such as plastic convertible top windows, bug shields, plastic marine windows, motorcycle windscreens and helmet face shields.
Regardless of where you live, your car's headlights are exposed to a variety of damaging environmental factors. Mothers PowerBall 4Lights Headlight Restoration Kit is designed to quickly and safely turn your dull, yellowed headlights to crystal clear in a few minutes. All you need to supply is a variable-speed cordless drill. Mothers PowerBall 4Lights Headlight Restoration Kit provides the rest.
![](http://i159.photobucket.com/albums/t158/zoomzoommazda5/classic-motoring_2094_8493425.gif)
The kit includes:
Mothers PowerPlastic Plastic Polish, 8 fl. oz.
PowerBall 4Lights
2 severe damage restoration pads
Microfiber towel
Basic directions for use:
Clean and dry the plastic surface
Mask off the area around the plastic to be restored to be cleaned with painter's tape.
Attach PowerBall 4Lights to any variable-speed drill (cordless suggested) and tighten the chuck.
Apply nickel-sized amount of PowerPlastic to the center of the ball.
Start drill motor slowly to avoid slinging adding polish as needed.
Polish in small areas using back and forth, overlapping motions until area is clear.
Buff clean with microfiber towel turning frequently for best results.
WARNING: WEAR PROPER SAFETY EQUIPMENT AND EYE PROTECTION DURING USE.
The kit includes:
PowerBall 4Lights
Microfiber towel
Angelo
Club Lexus Vendor Marketplace
02-14-11 11:35 AM
