Club Lexus Vendor Marketplace The place to find group buys and great deals from ClubLexus' supporting vendors.
WEDsSport Lightweight Track Wheels 18" @ 17 lbs **** IS Fitment ****
Old 02-23-10 | 09:00 PM
RavSpec's Avatar
RavSpec
Former Sponsor
Default WEDsSport Lightweight Track Wheels 18" @ 17 lbs **** IS Fitment ****
hey All:
Just got our hand on some WED sport lightweight track wheels. Anyone interested, please give us a call !
TC105N - $2089 Shipped to lower 48 states AMF Technology
Titanium Bronze Color
Available Spec:
18x8.5 +32 (16.9 lbs per wheel)
18x9.5 +35 (17.6 lbs per wheel)
18x10.0 +12 (18.4 lbs per wheel)
Old 02-23-10 | 09:02 PM
RavSpec's Avatar
RavSpec
Former Sponsor
WedsSport SA70 - $1820 Shipped to lower 48 states AMF Technology
Available Spec:
18x9.0 32mm offset or 20mm offset
18x10.0 32mm offset or 18m offset
Old 02-23-10 | 09:08 PM
RavSpec's Avatar
RavSpec
Former Sponsor
WedsSport SA67R - AMF Technology
Available Spec:
19x9.0 35mm offset / 19x10.0 42mm offset Gun Metal Color *** $2160 Shipped ***
19x8.0 35mm offset / 19x10.0 42mm offset Blue Light Chrome *** $2939 shipped ***
Old 02-24-10 | 12:37 AM
ISBU's Avatar
ISBU
SA70 shipped to 96797. Thanks.
Old 02-24-10 | 06:13 AM
lisc300's Avatar
lisc300
is that with tires or not nd what is the offset
Old 02-24-10 | 06:37 AM
RavSpec's Avatar
RavSpec
Former Sponsor
RavSpec's Avatar
RavSpec
Former Sponsor
not with tire .. offset info are listed on the post ....
Old 02-24-10 | 10:22 AM
HKS350's Avatar
HKS350
R these in stock?
Available Spec:
Old 02-24-10 | 11:10 AM
RavSpec's Avatar
RavSpec
Former Sponsor
Originally Posted by HKS350
R these in stock?
Available Spec:
yes they are !!
Old 02-24-10 | 01:42 PM
BS ISF's Avatar
BS ISF
Originally Posted by RavSpec
WedsSport SA67R -
Available Spec:
how much do these 19's weight?
Old 02-24-10 | 06:05 PM
RavSpec's Avatar
RavSpec
Former Sponsor
19x9.0 >>>> 9.49Kg〜= 20.8LB〜
19x10.0>>>9.98Kg〜= 21.9LB〜
19x8.0>>>>8.88Kg〜=19.5LB〜
Old 02-24-10 | 09:07 PM
ISBU's Avatar
ISBU
You don't ship to HAWAII?
Old 02-24-10 | 09:11 PM
RavSpec's Avatar
RavSpec
Former Sponsor
yeah sure ... just add $180 to that price, I'll ship it !
Old 03-05-10 | 09:11 PM
RavSpec's Avatar
RavSpec
Former Sponsor
Adding SA55M now
Old 03-11-10 | 07:24 AM
RavSpec's Avatar
RavSpec
Former Sponsor
(AMF Technology)
AMF (Advanced Metal Forming) is one variation of rotation forming process that rotates a metal pipe axis and casts the material on the roller.
Casting and Forging
Generally, the advantage of casting is that it melts aluminum alloy at high temperature and pours into a mold to form as one so the designing flexibility on the disc is pretty high thus it’s easy to mass produce and cost effective. On the other hand, from technical stand point, it’s hard to reduce weight since it’s difficult to form into thin metal. Also what was formed through casting is often uneven and particles are not cohesive therefore its strength is not good enough. On the other side, forged wheels are made by running a lump of aluminum or alloy into high-pressure pressing machine thus aluminum particles spread and formed according to wheel shape and it is stronger (Fiber Flow). Because of the way they are produced, forged wheels can be made light-weight. It seems like it’s perfect but there is a definite weakness of “It’s not flexible from design perspective. It has already been explained, forging process uses high rate of weight to form the shape consequently, it is not suitable for complicated cosmetic face design. Forging also has a disadvantage of being more expensive due to multi-processing.
"New method of manufacturing process" to make up for the weakness is born.
In AMF, first of all, simultaneously cast rim and disc. Secondary, cast disc (= rim material) is to be put through wheel-only spinning processor and roll the rim. It realizes more flexible and tenacious strength by having aluminum material’s crystal and macro formation get further detailed through being forged in this process. As a result, high-strength rim with “stretch strength,” “durability,” and “spread” which are basic characters required for aluminum wheels, is born. Now it is possible to create high-precision rim that is seamless tube as compared to the type that forms a sheet material into a ring through welding. AMF on disc surface is normally casted, it keeps design-flexibility, but it contributes to reduction of under spring load because the rim-part is spread thin as much as possible by spinning machine. Such new method of manufacturing process method is AMF which has the merit of both casting and forging. AMF was newly created the WedsSport brand concept “Faster, Safer.” New generation technology improved in motor sports enters the scene with superb performance.
