NEW *** WORK Emotion 11R FT Light Weight Tuning Wheel ***
![](http://www.ravspeconline.com/images/wheels/work/11rft/WFT_LOGO.png)
Just released from WORK Japan - WORK Emotion 11R FT.
Superb Durability, Extra Lightweight, Built For Track !
WORK Co. LTD has introduced a new version of Emotion 11R, EMOTION 11R-FT. This new wheel utlizes WORK Flowforming Technology, also known as spun forming here in the U.S.
The key benefit for flow forming is able to reduce the barrel thickness, thus reducing the weight of the wheel without compromising the strength of the rim barrel. The 11R-FT is a good choice for motorsports racing use or at area where there are smoother roads.
Unlike our competitors' flow forming wheels, WORK flow forming wheels start with low-pressure cast construction, whereas some of our competitors use lower quality gravity casting. Low-pressure cast construction has a denser material property over gravity cast wheels, thus allowing a greater strength advantage over gravity cast with flow-forming barrel.
Application available for both front wheel, rear wheel and all wheel drive vehicles. Depending on size and offset, the Emotion 11R-FT is available with semi-concave or deep concave face. Some specs are BBK friendly.
WEIGHT INFO:
18x8.0 - 19.5 lbs
18x8.5 - 20.6 lbs
18x9.5 - 21.5 lbs
18x10.5 *** Coming Soon ***
![](http://www.ravspeconline.com/images/wheels/work/11rft/11rft-1.jpg)
![](http://www.ravspeconline.com/images/wheels/work/11rft/11rft-2.jpg)
![](http://www.ravspeconline.com/images/wheels/work/11rft/11rft-evo1.jpg)
![](http://www.ravspeconline.com/images/wheels/work/11rft/11rft-evo2.jpg)
![](http://www.ravspeconline.com/images/wheels/work/11rft/11rft-grb1.jpg)
![](http://www.ravspeconline.com/images/wheels/work/11rft/11rft-grb2.jpg)
![](http://www.ravspeconline.com/images/wheels/work/11rft/11rft-bmw.jpg)
RavSpec
Club Lexus Vendor Marketplace
01-16-11 07:48 PM
A Spec
39
07-29-09 06:57 AM
