Meguiar's Solo System At ProperAutoCare.com
For our Meguiar's Folks who been asking about this system.
Compound & Polish Swirl-free in One Step
Meguiar's Cut & Polish Cream #86, from Meguiar's Solo One Liquid System, is perfect for one-step compounding and polishing with swirl-free results. Meguiar's Cut & Polish Cream utilizes uniformly sized, non-diminishing abrasives that provide varying results when used with different Solo pads.
![](http://i159.photobucket.com/albums/t158/zoomzoommazda5/classic-motoring_2103_35614373-1.gif)
Meguiar's 7" Solo "Diamond" Foam Finishing Pad is formed with diamonds cut into the face. This revolutionary design removes light swirls and holograms while delivering a swirl-free performance. Meguiar's 7" Solo Foam Finishing Pad diamond pattern also provides smoother buffing action with less chatter. Use this pad in conjunction with Meguiar's Solo One-Liquid Polishing System.
Meguiar's 7" Solo Foam Finishing Pad gray foam is an open cell structure so air flows through the pad as you use it to reduce heat. The foam also has just enough cut to remove fine swirls, but is soft enough to fit the shapes of your vehicle.
The backing of the Meguiar's 7" Solo Foam Finishing Pad is recessed to provide error-free centering on a 6" hook and loop backing, and an even connection to eliminate vibrations. This pad can be used on rotary polisher as well as orbital and dual action polishers.
Meguiar's recommends using Meguiar's 7" Solo Foam Finishing Pad on a rotary polisher with Meguiar's W66 "Easy-Buff" Backing Plate for Rotary Polishers. Use these pads on a dual-action polisher with Meguiar's Unigrit™ Professional 6" Backing Plate or any 6" backing plate of your choice.
Meguiar's 7" Solo Wool Light Cutting Pad has a unique 1" wool fiber blend for light cutting with less aggressive, safer cutting. This pad was specifically designed to work with Meguiar's #86 Solo Cut & Polish Cream. This combination will remove defects, level paint, and restore paint.
Meguiar's 7" Solo Wool Light Cutting Pad has a flat pad design which expands the cutting area to reduce buffing time. Shorter fibers are best for defect removal and gives a softer feel to reduce the possibility of overheating the paint.
The backing of the Meguiar's 7" Solo Wool Light Cutting Pad is recessed to provide error-free centering on a 6" hook and loop backing, and an even connection to eliminate vibrations. This pad can be used on rotary polisher as well as orbital and dual action polishers.
Meguiar's utilized advanced Unigrit™ Technology to deliver even cutting and polishing for light swirl and blemish removal. When Meguiar's Cut & Polish Cream is used with a Meguiar's Solo Wool Light Cutting Pad, you can accomplish most defect removal. Follow this with Meguiar's Solo Diamond Foam Polishing Pad to achieve a swirl-free finish.
The Meguiar's Solo System provides:
Both compounding and polishing in a one-liquid system
Advanced Unigrit™ Technology for level cutting and swirl removal
Designed for paint and body shops, but is user friendly
VOC compliant in all states
Eliminates multiple steps using multiple products
We recommend that the Solo System is best used with a rotary polisher.
![](http://i159.photobucket.com/albums/t158/zoomzoommazda5/classic-motoring_2103_35569526-1.gif)
![](http://i159.photobucket.com/albums/t158/zoomzoommazda5/classic-motoring_2092_17484385-1.gif)
![](http://i159.photobucket.com/albums/t158/zoomzoommazda5/classic-motoring_2109_19039414.gif)
![](http://i159.photobucket.com/albums/t158/zoomzoommazda5/classic-motoring_2109_19049447.gif)
![](http://i159.photobucket.com/albums/t158/zoomzoommazda5/classic-motoring_2109_19059192.gif)
Angelo
Club Lexus Vendor Marketplace
06-17-10 12:55 PM
Vi-Tuyen
Automotive Care & Detailing
29
02-20-09 08:22 PM
