Mishimoto Carbon fiber radiator caps and Oil Catch can!!!
Hello Guys,
Got some of these in stock ready to ship. Nice Carbon fiber upgrade under the hood!!!
Mishimoto brand:
The Mishimoto Aluminum Oil Catch Can will prevent a harmful buildup of oil inside of the turbocharger, intake manifold, intercooler and piping. Our catch can prevents oil from getting into pressurized turbo plumbing and stops oil vapors from getting into the intake system that would ultimately lead to lower combustion temperatures and reduced overall efficiency. The polished Mishimoto Aluminum Oil Catch Can comes complete as a kit containing a mounting bracket, hose, all necessary clamps, fittings, and mounting hardware, for a perfect upgrade in performance and aesthetics for your car.
Mishimoto has released a carbon fiber oil catch can. These units come with all necessary hardware
![](http://img18.imageshack.us/img18/7626/228qx.jpg)
Also new Flat black finish:
![](http://img816.imageshack.us/img816/6659/yhst6263165724858021203.jpg)
Mishimoto Aluminum Oil Catch Can - Small
![](http://img198.imageshack.us/img198/375/yhst6263165724858021732.jpg)
Mishimoto Aluminum Oil Catch Can - Large
![](http://img707.imageshack.us/img707/375/yhst6263165724858021732.jpg)
Mishimoto Aluminum Power Steering Reservoir Tank
![](http://img687.imageshack.us/img687/375/yhst6263165724858021732.jpg)
Mishimoto Aluminum Coolant Reservoir Tank
![](http://img196.imageshack.us/img196/9549/yhst6263165724858021731.jpg)
Weapon R polished oil catch can. $56.00 shipped
Made of Billet 6061 Aluminum and TIG Welded with Billet Aluminum machined fittings for a proper fitting seal. These tanks were designed with racers in mind to get down the track safely, by sending all your overflowing fluids to your catch tank and not the ground. Each Kit also comes with an aluminum bracket and stainless steel clamps for mounting. Included in each kit is 3 Feet of Clear Fiber Reinforced Tubing, to route your coolant or Oil Vapors. Vehicle specific tanks are made to fit to OEM bolt holes and require no modifications for installation.
Dimensions: 7.5" High / 3" Diameter. Capacity Aprox 24oz.
Dimensions: 6.5" High / 3" Diameter. Capacity Aprox 18oz
![](http://img215.imageshack.us/img215/1043/weaponrcatchcan.jpg)
Weapon R 24 fl oz coolant catch can: $56.00 shipped
Dimensions: 7.5" High / Overall Height 8.25" / 3" Diameter. Capacity Aprox 24oz
![](http://img7.imageshack.us/img7/7329/1252508486weaponrcoolan.jpg)
Mishimoto Carbon fiber Radiator cap:
$37.00 Shipped inside the USA
![](http://img195.imageshack.us/img195/6899/yhst6263165724858021001.jpg)
Mishimoto Radiator cap with built in Temp guage:
$53.00 Shipped inside the USA
![](http://img72.imageshack.us/img72/9003/yhst6263165724858020985.jpg)
![](http://img203.imageshack.us/img203/7307/yhst6263165724858020991.jpg)
Please pm me or call 813-787-4075 with any questions you have.
Thanks
Charles
Mishimoto brand:
Thanks
Charles
