Club Lexus Vendor Marketplace The place to find group buys and great deals from ClubLexus' supporting vendors.
>> Mod-Express.com - JL HID Conversion Kits starting at $39.99!
Old 01-21-11, 08:20 AM
  #61
ModExpress
Former Sponsor
ModExpress's Avatar
55W's are now back in stock. All backorder 55W orders will be fulfilled today!
Old 01-22-11, 03:58 PM
  #62
ModExpress
Former Sponsor
ModExpress's Avatar
All orders have gone out, however tracking numbers will not be updated until Monday.
Old 01-23-11, 11:17 AM
  #63
ModExpress
Former Sponsor
ModExpress's Avatar
Hope your having a good weekend! All orders over the weekend will go out first thing Monday morning!
Old 01-23-11, 04:29 PM
  #64
cyberlexus
cyberlexus's Avatar
Will the 55W kit be using different bulbs compared to the 35W kit?
Old 01-23-11, 06:16 PM
  #65
ModExpress
Former Sponsor
ModExpress's Avatar
Yes the 55W kits will be utilizing 55W rated bulbs, if you use 35W rated bulbs on a 55W ballast the bulb will color decay and burn out at a very fast rate.
Old 01-24-11, 08:59 AM
  #66
t.is350.h
t.is350.h's Avatar
For this JL kit do you have 9003(dual beam)? I can't find it on your website. Thanks
Old 01-24-11, 10:27 AM
  #67
ModExpress
Former Sponsor
ModExpress's Avatar
9003 is the same size as H4, let me know if you have any other questions.
Old 01-24-11, 11:13 AM
  #68
Milan
Milan's Avatar
Originally Posted by ModExpress
Everything is covered from the bulb down to the wiring to the ballast, 5 years from now if it burns out we'll replace it free of charge.
That's awesome! Expect me to order a set from you when it warms up a bit.
Old 01-24-11, 11:25 AM
  #69
ModExpress
Former Sponsor
ModExpress's Avatar
Sounds good
Old 01-25-11, 10:27 AM
  #70
fasteddy91
fasteddy91's Avatar
Quick question. I currently have a H9 35 watt HID kit from a different vendor for my MR2and the issue I am having with that kit is the headlights will flicker and turn off once I turn the car off. If I turn the lights on when the engine is not running, the lights will come on go a moment and turn off. While the engine is running, there is no problems. Will your relay kit fix this problem?
If I decide to go with your 55 watt HID kit, do you think I need to run your relay?
Thanks.
Old 01-25-11, 01:03 PM
  #71
ModExpress
Former Sponsor
ModExpress's Avatar
Thanks.
It does sound like a relay would fix this issue, since the kit you have right now is probably drawing an insufficient amount of power when your car is off.
Our 55W kits do not require a relay harness, but it is recommended since it requires a higher Amp draw than the 35W and it puts more strain on your factory harness.
Old 01-25-11, 01:40 PM
  #72
fasteddy91
fasteddy91's Avatar
^Thanks for the reply back. The relay you sell "a one size fit all" ?
Thanks again.
Old 01-25-11, 01:43 PM
  #73
ModExpress
Former Sponsor
ModExpress's Avatar
Thanks again.
Not a problem, yep universal fitment.
Old 01-25-11, 07:36 PM
  #74
fasteddy91
fasteddy91's Avatar
About to order the relay harness....dumb question, do they come with instructions?
Old 01-25-11, 08:47 PM
  #75
ModExpress
Former Sponsor
ModExpress's Avatar
We have instructions in PDF format if you have trouble installing the kit, but I don't think you'll have an issue.
Quick Reply: >> Mod-Express.com - JL HID Conversion Kits starting at $39.99!
