Club Lexus Vendor Marketplace The place to find group buys and great deals from ClubLexus' supporting vendors.
Sikky ISF/250/350 Adjustable Rear Sway Bars!!
Old 12-16-11, 12:54 PM
JE
Former Sponsor
JE's Avatar
Default Sikky ISF/250/350 Adjustable Rear Sway Bars!!
Hey everyone
We were lucky enough to get the chance to install and test one of Sikky’s new Lexus ISF/250/350 rear sway bars! Everything with the install went smoothly and according to plan. The sway bar comes with all the necessary hardware including some really nice urethane bushings to replace the factory units and heavy duty heim joint endlink sets with adjustable preload turnbuckles. As per all Sikky products the quality was top notch. With it being 3 way adjustable you are able to set the bar stiffness to work best for your setup which is a really nice feature. The softest setting is equivelant to a Fsport bar but the two stiffer settings allow you to compensate for larger tires or more aggressive driving style. Check out a few pics below to see the final product. You can contact us locally to get one installed or go direct to Sikky to purchase a sway bar. Here is the link to their website:
http://www.sikky.com/view_item.php?id=162&catid=14
Everything taken out of the box ready for install:
Here's us removing the FSport bar:
New Sikky bar going in!
Close up shot of the Sikky endlink setup installed:
Installed and ready to go:
Old 12-18-11, 09:00 AM
FIGS
The Maker
FIGS's Avatar
Can you post picks of the suspension loaded and the endlink from the rear? Wondering about minimum preload.
Thanks ,
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 12-21-11, 10:59 AM
JE
Former Sponsor
JE's Avatar
Introductory price now at $299.95
Get them while they're hot
Specifications:
3/4" diameter bar with 3 position adjustable endlink setup
Old 12-21-11, 11:27 AM
Fajen
Fajen's Avatar
Just FYI:
while I haven't done this mod on my car yet, I will say that the adj. sway bars are, without a doubt my favorite modification ever. I did it to my STi and it made an incredible difference.
I look forward to get these for the IS-F sometime soon.
Old 12-21-11, 12:46 PM
flowrider
flowrider's Avatar
Received 1,920 Likes on 1,355 Posts
Before you folks jump, look at posts 6 and 7 here:
https://www.clublexus.com/forums/sus...sway-bars.html
I have the F-Sport rear bar and have been extremely happy with it.
Lou
Old 12-22-11, 01:52 AM
steezy
steezy's Avatar
These are look awesome. Just as thick as any of the sway bars out there. but with 3 adjustments, should be better that hotchkis...
Old 12-22-11, 06:13 AM
jaslapp1
jaslapp1's Avatar
Lou the shots are from my car. I had the pleasure to get my hands on one of the first sets. I for one am very pleased with the sikky sway bar. The softest setting is equivalent to the f sport. I originally liked my f sport but when I put bigger wheels on the car I had some understeer once again. I'm running it on the second setting. This setting is quite a bit stiffer then the f sport. I believe it has improved handeling greatly. The car feels more solid and the understeer is gone. I can't wait till spring time to play with the 3rd setting at the track.
Old 12-22-11, 09:36 AM
JE
Former Sponsor
JE's Avatar
Jason is correct. The most outer setting on the Sikky bar, softest, is equivalent to the F-sport bar. I contacted SIKKY in reference to more details on the three different settings and was supplied a detailed list of approximate stiffness rates. These number are in a relation to the STOCK bars.
IS250/ISF:
Outer: 48%
Middle: 92%
Inner: 173%
IS350:
Outer: 157%
Middle: 201%
Inner: 282%
Old 12-28-11, 08:16 AM
JE
Former Sponsor
JE's Avatar
These bars are selling fast. Get them while you still can at the low introductory price. Order now!
LexBrett
01-09-15 04:20 PM
FIGS
IS F (2008-2014)
09-13-13 08:23 AM
JE
15
03-19-13 09:10 AM
JE
12-30-11 10:39 AM
Kevin.IS
28
05-21-10 01:36 PM
Quick Reply: Sikky ISF/250/350 Adjustable Rear Sway Bars!!
