Universal TPMS System. Improves fuel economy!!
Hello Guys,
Just got these in ready to ship. Great way to monitor your tire pressure.
Davies Craig TyreGuard 400 (TPMS) Kit:
Increases drving safety
Maximize tire life
Simple DIY Installation.
The Davies Craig TyreGuard 400 TPMS (Tire Pressure Monitoring System) is a unique electronic safety system for monitoring air pressure and temperature in tires. It consists of simple easy- to-install, screw on sensors and a hand-held monitor. Fixed to the tire valve, each sensor monitors the individual air pressure and temperature inside the tire, and then transmits the air pressure and temperature information to the monitor. This information is then graphically illustrated on the monitor screen and the operator can scroll through the data for each individual tire. Each sensor/tire can be individually set to the pressure you wish to operate in the respective tires. An audible alarm will sound and the red LED light will flash should the tire pressure and/or temperature vary markedly from each tire’s targeted air and temperature settings. The TyreGuard will monitor the air pressure and temperature of up to 22 tires with a pressure range of 0 to 145 psi and sensors within 7.6 meters of the device or 16 meters with the use of a signal booster.
Check link for pricing. These are in stock and ready to ship
http://www.b2autodesigns.com/product...oducts_id=5295
Please pm me or call us 813-787-4075 with any questions you might have.
Thanks
Charles
Maximize tire life
Thanks
Charles
RiojaRed
09-25-17 11:54 AM
HOLGER21
06-20-17 05:21 AM
