C8SPORT SSD+ 30-Step Coilover Systems
Former Sponsor
C8SPORT SSD+ 30-STEP Coilover System
New for 2012!
Follow us on Facebook! C8SPORT
The C8 Silver Sport Damper Plus (SSD+) system is an advanced-level height and 30-step dampening adjustable coilover suspension system designed for those who strive to win. C8 SSD+ exemplifies the winning mentality that accompanies every podium finish and the passion for driving that makes every straight away and every corner pass by with the blink of an eye. Created with a color scheme symbolizing elegance and simplicity, the C8 SSD+ system fades into the shadows of your fine-tuned machine while you focus on pushing every last horse to the finish line. Fewer steps of dampening are provided to allow for quick adjustments when time is of essence. There is a reason why champions are born every day and a reason why the C8 SSD+ System is necessary for that mission. All C8 SSD+ Systems carry a limited one-year warranty and incorporate research and development gained from worldwide racing programs.
FEATURES
SPRING RATES
CONTENTS
New for 2012!
FEATURES
- 30 levels of adjustable damping
- Upper Mounts Made from high quality 6061 aluminum with T6 for increased hardness
- Adjustable spring perch for height adjustment
- Adjustable body allowing maximum suspension travel
- Monotube high pressure design reduces oil leakage
- Electroplated body for protection from corrosion and rust
- Limited 1-year manufacturers warranty
SPRING RATES
- 98-05 GS300/GS400: 12kg front, 8kg rear
- 06+ GS430: 12kg front, 8kg rear
- 01-05 IS300: 12kg front, 8kg rear
- 06+ IS250/IS350 RWD: 12kg front, 8kg rear
- 92-99 SC300/SC400: 14kg front, 12kg rear
- 86-92 Supra: 12kg front, 10kg rear
- We stock a lot more than just Lexus and Toyota applications. If there are any other applications, let us know!
CONTENTS
- Set of four coilovers: front left, front right, rear left, and rear right
- Spanning adjustment wrenches
- Dampening adjustment keys
