Ichiba V1 or V2 hub centric wheel spacer kits 5mm-38mm: Fits IS,GS,LS,SC and CT200H
Hi Members,
We are a direct dealer of Ichiba USA.
B2Autodesigns is offering Ichiba Spacer kits in two different styles.
First is the Standard Spacer with longer studs.
Ichiba Wheel Spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
All are Sold as one pair (2pcs) with 10pcs of longer studs.
Ichiba V1 Offered in
5mm, 10mm, 12mm, 15mm, 17mm, or 20mm Kits
![](http://imagizer.imageshack.us/v2/800x600q90/841/qfj4.jpg)
The Second Verison come with the studs already in the Spacer, The 15mm and 20mm kit would require you to take a look at the wheels you have to make sure that the back pad of the wheel (where the lugs go through) have indentations next to it, allowing the left over factory stud to come through.
Version II wheel spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. Each wheel spacers are two pieces design with pressed studs. Now it's time to bolt-on without any swap studs hassles. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
Offered in
New sizes offered Also offered in 15, 17, 20, 22, 25, 27, 30, 32, 35 and 38mm All in stock ready to ship. Pm me for pricing
![](http://imagizer.imageshack.us/v2/800x600q90/834/xzyd.jpg)
Lexus CT200H applications available. Please message me with any questions. Don't have a Lexus? looking for another car. Message me I can help you out with fitment.
Please email us cback@b2autodesigns.com for questions or pricing.
Thanks
Charles
Offered in
Thanks
Charles
