JULY 4TH SPECIALS | STANCE WHEELS l ROTARY FLOW l AR MOTORWERKZ
AR MOTORWERKZ is proud to be STANCE WHEELS official dealer and distributer for the CLUB LEXUS forums.
STANCE WHEELS provides fast turn around times, customizable offsets, sizes, and finishes for an affordable price.
STANCE WHEELS with 15 years of experience in the wheel industry, Stance wheels strives to create new and unique designs. Available from 15"-20" wheels in a wide range of widths and offsets. Stance wheels will push the limits on fitment, colors, and styles. Our goals are simple offer great customer service, quality, great looking designs, and one of best wheel craftsmanship in the market today.
STANCE WHEELS SF01
The SF01 is the first design in our rotary flow line up. Using the rotary flow method allows us to build the SF01 stronger and lighter then cast wheels, weighting in at only 22-24 pounds per wheel.
The SF01 is a true directional wheel that allows wheel rotation to be the same on both driver and passenger side. The SF01 will be available in our standard Brush Face Silver color and our signature Brush Titanium.
STANCE WHEELS SF02
The SF02 is the second design in our rotary flow line up. Using the rotary flow method allows us to build the SF02 stronger and lighter then cast wheels, weighting in at only 22-24 pounds per wheel.
The SF02 is a mutli spoke wheel with a web design that allows the wheel to give you a unique look.The SF02 will be available in our standard Brush Face Silver color, Brush Titanium and Brush Bronze.
STANCE WHEELS SF03
Using the rotary flow forge method allows us to build the SF03 stronger and lighter then cast wheels, weighting in at only 22-24 pounds per wheel.
The SF03 is a split 5 spoke U-design that allows the wheel to give your brakes more air and helps show off your big brake system. Wheels will be available in our standard Brush Face Silver color, Gloss Black Tinted Machince and and our signature Brush Titanium.
STANCE WHEELS SF04
Using rotary flow forge method allows us to build the SF04 stronger and lighter then cast wheels, weighting in at only 22-25 pounds per wheel.
The SF04 is a split 5 spoke design and a true directional wheels.. Wheels will be available in our standard Satin black, Gloss Black Machince and and our signature Brush Titanium.
STANCE WHEELS SF06
Using the rotary flow forged method allows us to build the SF06 stronger and lighter then cast wheels, weighting in at only 25 pounds per wheel IN 20X10 &20X11.
