Does anyone know I can find this piece alone for the 2017 ct200 storage compartment? And do you know the part number? Thanks. Also didn’t glove compartment (side arm compartment) come with anything or was it just empty? Thanks
My CT had a little coin holder tray that just sat in the inside. I removed it since I don't use it and tucked it in the primary glove box.
The CT has a pretty deep center console. So, what I did is I got a tray that snaps into place that makes the storage much more shallow and usable for small objects. I can always manually pull the tray out should I want to store something beneath it.
Was this on the car originally? Or it’s an aftermarket thing? I also seen this online while searching stuff up. Had me curious. But I am looking for that one little shelf thingy for the storage compartment. Mine never came with one. Guessing previous owner broke it
This center console shelf is aftermarket (I bought it myself) but I think a welcomed edition to the car, for sure. As I said, the center console storage is quite deep so this helps to bring small items up to the top for easy access.
As far as the shelf in the glovebox, mine is there. It's just designed for the manual to sit on top of the shelf and then you can put other things below it (insurance info, or whatever you'd like there)...
I can check and see if I can obtain a part number for you.
