How clean permanent codes
1st Gear
Hello Club, I need your help to know how to remove the permanent codes from the computer, the oxigen sensors Upstream and downstream were replaced and some of the failures were removed but still have the permanent codes and the check engine light is back again
My car is a 2013 CT200h
P0031
P0038
P0171
P219A
P0031
P0038
P0171
P219A
My understanding is that if these codes and check engine light come back, it's because the problems still exist.
Agree with above post, if CEL was off and returned, a problem persists. Note - some codes can not be removed from memory. If the underlying problem has been fixed, the CEL will remain off, but the code will stay stored in memory. The code will clear itself after certain parameters are met, one of which will be fixing the issue.
https://www.bar.ca.gov/industry/pdtc...first%20place.
massakill
Performance & Maintenance
11-03-18 08:06 PM
