Rear left window wont go down
Hello!
Anyone got next problem or any idea what to check:
Rear left window wont anymore go down on door switch.
Driver panel works normally, so you can roll rear window up and down and one touch even works.
Rear door switch will roll window up and you even able to stop rolling by pressing window down button, but window downrolling wont work from door.
Very mysterious problem.
I tried to disconnect door switch cable and connect back but that wont solve problem. Also car battery disconnect wont solve this.
Please help anyone?
-Mikko
Please help anyone?
-Mikko
The switch, or switch module in the door could be defective. You might want to try seeing if you can plug the switch assembly from the other side of the car into the problem side to check if it works (not sure if they're plug-compatible, but easy enough to try)
I'm pretty sure you have to normalize the system? I feel like I just ran into this when I disconnected the battery. Our Mercedes is the same way.
I couldn't roll any of the windows down other than from the driver panel.
Roll window all the way down making sure NOT to do the double click for the auto. Once it is rolled down and you still have your finger on the switch, push it in more so it clicks to the second position. Do the same thing with the window going UP. Once it's at the top pull the switch more to engage the second click.
Now go to the window control of that seat and it should work. I think I had to do this with all three windows.
-Nigel
-Nigel
KKM (06-22-24)
-Nigel
-Nigel
Dont know it older or newer CTs have need for initialization.
I also have 2006 Lexus GS 450h you have to initialize the windows separately, but looks like not in this car.
I also thought it will need but no.
I have to test that switch on other side window to check if its defective and also if there's some wire poor connection somewhere in door.
