linear valve offset not performed
Hello guys, I have Lexus CT200h 2011, initially i had a problem with the stoke sensor was acting up, ABS/Traction?brake warning light were coming up and when reset it goes, then when tried to replace the stroke sensor it give me an error of (linear valve offset not performed) i did calibrate the stroke sensor to give the values (0.8v / 4.17v) been trying to do the linear valve offset calibration but its not going through, sometimes it stops by second between (20s to 15s) and lights go solid never getting the quick flashing, sometimes even it goes even beyond 120s and it is still trying to calibrate then lights go solid and calibration would not take place,, i have tried bleeding multiple times but cant seem to be able to make the car perform the offset valve calibration.. any ideas ?? note i use maxis scan tool..
to all those facing this same exact issue which apparently is common i have figured it out, you have to be very patience step one, step 2 you have to perform under special function "air bleeding" follow the steps and bleed almost 400ml of each tyre, then perform the linear valve offset learn under ECB, surprisingly it didnt even took 120s, at second 70 of the drp down counter all light started flashing quickly indicating learning is done..
best of luck hope this be useful to someone some day
pragma
CT 200h Model (2011-2017)
04-02-24 12:02 PM
gs300_94
GS - 1st Gen (1993-1997)
11-05-09 08:22 PM
