Lexus CT200h engine shakes at low rpm (eco zone)
Hi,
Been using lexus CT 200h for about 2 years now. Recently I've noticed some weird engine shaking when driving at low rpm (exactly when speedometer hand is in a middle of ECO zone). Lexus dealer says everything is alrihgt. There are not engine failures etc. It happens mostly when the engine is cold, or is noticeable when driving uphill.
Has anyone come across a solution? Been searching the web but with no results.
Hi,
I'd recommend doing an intake manifold clean, EGR valve/pipe/cooler service as this is always smart on these engines and don't be afraid to drive briskly to clean out some of the carbon (disclaimer: always drive safe).
The engine will also go into a higher rpm/load demand mode when you bring the HV battery into a low state of charge..last bar remaining on the dash gauge (think: stop and go traffic in electric mode with the A/C on lots) as it serves to bring the state of charge back up quickly.
It sounds like your headgasket is going bad. It's an extremely common issue on these cars, exactly with the symptoms you describe. It's especially noticeable every time the engine comes on (like in the middle of the eco range) while it's cold and not warmed up yet. The EGR system is clogged and the headgasket can't handle the pressure and blows out, causing oil and coolant to mix and flood the spark plugs. it will get worse, and you'll eventually get misfire check engine light codes.
Acrad
10-23-21 10:13 AM
aseruf
05-08-18 02:35 PM
LexFather
CT 200h Model (2011-2017)
05-23-11 03:32 AM
