CT 200h Model (2011-2017)
Enkei 18" raijin wheels
Old 08-09-12, 11:35 PM
aau
aau's Avatar
Default Enkei 18" raijin wheels
Enkei Raijin 18"
Hi guys,
Does anyone know if the new enkei Raijin Will fit our ct?
18x8
Offset +45
Bore diameter 72.6
5x100
http://www.enkei.com/raijin.shtml
Tires would be 225/40/18, is it possible to run 215/40/18?
Thanks in advance!
Old 08-10-12, 11:10 AM
TR3XX
TR3XX's Avatar
those will look sweet on a CT
Old 08-10-12, 04:20 PM
aau
aau's Avatar
OK, did some more research
CT200h Stock OEM wheel:
17x7.0 5x100 +45
bore diameter: 54.1
tires: 215/45/17
V.S.
Enkei Raijin:
18x8.0 5x100 +45
bore diameter 73
tires: 215/40/18
Per offset calculator: -13mm on inner side and extend 13mm on outer side (based on +45)
My questions:
1) Will this setup be possible for my CT?
2) The Enkeis comes in +32 offset as well, should I go with +45 or +32?
3) Should I go with 225/40/18 or 215/40/18?
4) The bore diameter is quite different, will this wheel even fit for CT?
Thanks in advance!
Old 08-11-12, 02:48 AM
Tennis100
Tennis100's Avatar
Can't help you out with the technical questions..... but I have to say that those are going to look absolutely SICK on the CT. Especially in black..
aau
Wheels, Tires & Brakes Forum
08-14-12 05:34 AM
Maxx941
04-27-10 12:30 AM
NORCAL SS
12-30-08 12:21 AM
Nline6
Wheels and Tires Classifieds
09-10-08 07:06 PM
whj27484
11-28-06 10:46 PM
Quick Reply: Enkei 18" raijin wheels
