Anyone running wheel spacers with stock wheels?
#31
#1 What is the minimum size spacer do I need to clear the factory studs without modification (no cutting), in the event I need to put a spare tire on?
#2 What is the maximum size spacer anyone has used (using stock wheel/tires) without rubbing of any kind regardless of the drop?
#32
Q: What is the minimum size spacer do I need to clear the factory studs without modification (no cutting), in the event I need to put a spare tire on?
After having gone through this personally, I can answer my own question.
A: 25mm
A: 25mm
#34
