How to clean the evaporator core?
Does anyone know where to connect the evaporator core cleaner? The foam cleaner has a tube that connects to...
Any help would be appreciated.
Thanks
Thanks
Happy Motoring.
If you run the fresh air vent when you run the A/C you shouldn't have a problem, or switch to fresh air before you reach your destination.
Needless to say we are both on fresh air ventilation.
I have used a similar product called Einszett Klima Cleaner on a few cars and their instructions are to insert it into the center dash vents to let the foam surround and clean the evaporator. It works very well. I do not see how shooting it up the water drain tube could accomplish as thorough a cleaning.
http://www.1z-usa.com/klima-cleaner_application.html
Years ago I was at my local Honda dealer when they had terrible A/C mold problems and this was before the invention of products like Klima Cleaner or BG Frigi Fresh. The dealer had cases of Lysol spray disenfectant which they advised were sprayed in all the vents inside and outside the car!
Sewell Lexus Parts sells a 2 step Toyota AC refresher kit fir about $20.
My local Lexus dealer did mine under warranty at 10 months for free.
I was also told to switch to outside air rather than recirculate prior to shutting down to park.
JR
JR
This happened on my gf's 2011 BMW 328i last year. However she took it to the dealer and they did the service.
Needless to say we are both on fresh air ventilation.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
The fact is there is no repair for this Foul Odor and Lexus states that fact, not all vehicle with get that Foul Odor but some vehicle will get it. I know I am a lemon law expert and mechanic with over 40 years hand on experience.
If you want a temporary repair just like the one the dealership offer for over $100 do it or you can do what I do on my customers cars.
Here is what I do, I use 2 oz of bleach in 1 qt of water and spray it into the air vents with the AC on Fan on High and the engine is running, all door open. This will kill the bacteria and give you fresh air for all summer. You must allow all of the bleach smell to exit the vehicle before driving. All fans on high and all door or window open until clear before driving. This does work and cause no harm to any parts.
