Any consensus about solid HID kit?
#32
Ok, so proabably going with a set of H11B's unless anyone has a reason why another set that is slightly cheaper is worth it. Also, it was mentioned that someone on here is a dealer for them, anyone know who?
#33
the xtreme kit has a lower drawing ballast compare to the volt kit. and from what i gathered, the ballast in the xtreme kit is the lowest drawing compare to their competitors. and the reason i make mention of this is because i've been using this without a relay or stand alone canbus and haven't ran into any mis firing issues at all. i went cheap and didn't choose the more expensive xtreme kit which comes with the philips bulb. (costs $45 more)
http://www.kbcarstuff.com/Xtreme-HID-Kits-s/9954.htm
and also, if you're worried about that weird shadow that you get with the h11 (not H11B, H11B you don't get the shadow) kit from morimoto, there's none of that with the xtreme kit from kbcarstuff.
i still have a write a full review on this kit. i would recommend this kit to others.
you can also use the promo code CL to get 15% off.
#34
i've had the xtreme kit from hbcarstuff.com for over a month now.
#35
Former Sponsor
Sounds good ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I'm obviously biased, but we have been a trusted vendor on this site for YEARS for a reason. You will not go wrong with the Xtreme HID kit. You're NOT going to run into any return wire shadows like you do on other kits, no radio interference, power steering issues, etc..
ClubLexus members get an additional $25 off by using coupon code CL. The $129.99 SHIPPED price is literally the lowest price we've ever offered this kit for and will not last for long. Take advantage while you can![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
kl25: Hope you're doing well! I appreciate the feedback.
CarlitosPR
04-07-08 08:33 AM
