CT 200h Model (2011-2017)
Painted grill surrounds 2014 ct200h F sport!
Old 11-01-19, 12:08 PM
  #46
E46CT
E46CT's Avatar
Received 2,215 Likes on 1,658 Posts
Looks good. subtle and high quality. scuffing the little crevices of the grill must be hell. i am sure you did each and every hole on all sides, so the paint wont peel later on. Good work and well worth it. I am thinking of just doing all black in the front and just buying the OEM chrome molding for the bottom. yeah the upper grill surround, i know exactly where it likes to peel , the little inside corners on the upper part. i think those insides need to be tucked and pulled in first then wrap everything else after that. that's what's holding me back from wrapping the grill. i tried it in two pieces on the car before and it didn't look that good and peeled. so i removed it all.
Old 02-06-20, 05:27 PM
  #47
Indolent
Indolent's Avatar
Update, I ditched my expensive chrome wrap and bought OEM black chrome mouldings. I also resprayed the radiator grille due to rock chips.
Old 02-07-20, 12:50 PM
  #48
E46CT
E46CT's Avatar
^looks even better. Where did you buy those moldings? Are those an option? (drawing a blank right now)
btw you need to gloss out your mirror triangles, side pillar posts, and windshield posts like i did gloss black. HUGE difference. trim too if you haven't done that.
Old 02-09-20, 06:52 PM
  #49
Indolent
Indolent's Avatar
Lexus Boutique International / Japan, 2018+ uses the same moulding, it's just black chrome. Before it was advertised as only for 2018-2019, but I asked them if it will work and later replied back saying it will fit. I got it on sale with a discount code to help with the high shipping costs, but I'm still happy with how it looks.
A buddy of mine did my chrome delete, side pillar posts using the same vivvid wrap. Definitely digging the high gloss, he just had a harder time having it stick compared to 3m/avery despite using the adhesion promoter. I have yet to do the windshield posts and the triangle. I've also sprayed the rear bumper marker/reflector gloss black during the LEDIN/LED marker install
Old 02-13-20, 02:24 PM
  #50
E46CT
E46CT's Avatar
show us how the reflector part came out. i want to do mine too. that mesh looks hard to prep.
and yes vvivid is the only black gloss vinyl i use. 3m is trash. the ones on my mirror still look like paint. going on 2 years now!
Old 02-13-20, 02:26 PM
  #51
E46CT
E46CT's Avatar
Also looks like you did the headlight corners like mine too =P I need to re-do mine cause the CF vinyl (generic chinese) is starting to crack. i think cause there is a void in the headlight.. like a little strip that the vinyl doesn't want to lay into. no biggy the stuff is cheep and i have yard of it.
Old 02-16-20, 12:41 PM
  #52
Indolent
Indolent's Avatar
Here it is, since you did the LEDIN lights, I have a feeling you'll want to put the OEM lens on as well
MikeFoxx
06-24-12 06:48 AM
voleduy
IS - 1st Gen (2001-2005)
10-30-11 02:05 PM
chuckb
02-19-06 05:58 AM
koreanpers
08-01-04 11:32 PM
Quick Reply: Painted grill surrounds 2014 ct200h F sport!
