Spacers. Who has them and what do you recommend?
Hello,
I picked up my F sport last night and it came with F Sport lowering springs which was pretty cool.
I wanted to space out the wheels for a flush to the fender look.
What brand and size do you all recommend? From the looks of it I'm guessing 18mm to 20mm all around.
Thanks in advance,
Kevin
Thanks in advance,
Kevin
I do not have them on my CT but do have H&R Springs Track Plus spacers on my RX350. They are hub centric and made in Germany. I think they may be the best you can get. The web site helps you determine what size to get. I have 20mm on each side of my RX. Look at our sister forum because I think some folks there have spacers. http://www.ct200hforum.com/
http://www.trakplus.com/
If they do not make them for the CT, I know there are other brands such as Ichiba.
I found a post at the other forum
http://www.ct200hforum.com/forum/lex...cers-size.html
I did not see that H&R offered them for the CT. However, I suspect the Matrix ones may fit. Our car is based on the Matrix/Corolla platform. I think the big difference may be in the rear if they have drum brakes as opposed to disk.
The ones I got were the DRM style which were a simple take off your wheel, bolt on the spacer with their lug nuts, using a torque wrench, then bolt your wheels onto the spacers, using a torque wrench. Then retorque the wheel nuts after 100 miles or so.
http://www.2kracing.com/Universal_Su...l_Spacers.html
Personally, i'd go h&r over ichiban.
I just did a quick google search so there might be cheaper options out there, but h&r Scion spacers should work. Same bolt pattern (5x100) and center bore (54):
I'm thinking 20mm front and 25mm rear. Does that sound about right?
You can find the H&R spacers for less from other sources than H&R directly. The price from 2kracing is about $10 less a pair than from H&R.
If you go 25 front and rear you can get the DRM model and install them yourself if you have a torque wrench. The wheel bolt torque is 70 pounds.
I've looked into this between a couple forums. With stock tires, it would seem that you have 20mm in the front and 30mm in the back. However, I've read that spacers that are <25mm will require you to shave off the existing studs to clear the spacer. This is all subjective information. I'm actually going to be putting in new wheels/tires in the next few days (maybe today!) and will be able to give some objective info soon since I may need to put in 5-10mm spacers in the back.
i have spacers and extended studs on my CT. H&R track plus. i also have work 17x7 +38 cr ultimates. the front have 10mm spacers and the rear have 15mm spacers. i dont rub. i could go a lil wider and probs an extra 3-5 mm without rubbing but i'm currently leading the full functional life.
check out my build thread here! https://www.clublexus.com/forums/ct-...-and-more.html - i haven't updated in a while but i've done a few more things since then. i've been lazy with the forum upkeep lol
