Mini VCI Cable TechStream
Thanks for that great writeup. I ordered one of the 'wrong' 1.4.1 cables two days before you wrote this! I hooked it up last night, and it seemed to work okay except for the fact that I cannot get to the engine ECU, which is what I really need to look at. I found the link this morning to the AliExpress one you mentioned with 2.0.4 firmware. I am planning on ordering one of those. Even at double the price (which I will have ended up paying) its still worth the cost. Thanks again!
Excuse me while I vent a little.
I sold the 1st cable I bought on EBay for $4. Full disclosure. I stated clearly there was no K-Line support and that it only works on older Toyotas. I stated very clearly it will not work with newer Toyotas.
Buyer wants a refund because he can't install the software correctly. He says the cable is a fake. I told him there are no "official" installation instructions. All of these cables are knock offs. If he wants a "real" cable he has to buy the Techstream cable for $5000. I also sent him links to installation instructions.
What the hell is wrong with people? You buy a cable for $4 that normally costs $5000. What the hell do you expect?!! If you don't want to spend the effort to hack the installation then buy the "real" thing. You buy a knock off and expect everything to be just plug and play?! Idiot.
I can't tell if this guy is a scammer or just that stupid.
Stupidest thing is if he just followed the instructions found here or any widely available forum he'd see how easy it is to do. If you dont know about hacking the install you shouldn't even be working on your car with this cable. What a moron.
Agree with nacke. eBay does nothing to protect honest sellers. Any idiot can complain about something and the seller is screwed.
Good guys win!
I contacted eBay and they agreed to remove the negative feedback because the buyer violated their policy. The buyer threatened me with negative feedback unless I offered a refund including free return shipping. I offered to refund him if he shipped the cable back. Whew!
I actually sent a link to the buyer to this thread hoping he finally understands it's no one's fault. If he would just stop complaining, listen, and then follow the installation instructions I sent him, he would learn that his cable works fine (no K-line). I've done all I can.
Nope. Even after sending this thread to the buyer he still doesn't understand.
Also says he would never have bought the cable if he knew it was fake. It cost $4. Really? You thought this was a real Toyota cable for $4? Moron.
This is the 2nd (correct) cable I ordered:
http://www.aliexpress.com/store/prod...671740274.html
I ordered it specifically because they address the K-Line issue AND because they show the firmware version.
I asked 5 sellers on feebay about the firmware and only 1 of them knew. That one told me it was 1.4.1. They also said their cable supports K-Line which is blatantly false. I highly recommend avoiding feebay and Amazon unless the specifically tell you the firmware version. Lots of people have ordered on feebay and got the right cable. It's a gamble but better to ask. At least you can make a claim if they tell you something false.
Sorry for the question, I am very curious as to how much we can modify/re-program.
Thanks in advance!
I was going to get a WiFi ODBII, and the Carista iPhone app. I thought with this combo, i could do all that the Techstream can...what did I miss?
I want to be able to change settings that would otherwise require a trip to the dealer.
Had a chance today to give Techstream another try. I wasn't trying to change any ECU's or TPMS or anything, just wanted to disable the reverse beeping and the seat belt alarms. Before, I was using an older version of TS, so I think maybe that was the reason it didn't give me these options before.
I purchased the cheap mini VCI cable from ebay which had firmware version 1.4 on it and followed the instructions from the FT86club forums using TS v10.00.028 on Win 8.1.
You're right! Thanks man.
I have updated my original post. In the original post I talked a lot about K-Line support. I have since learned that K-line seems to only be required for older vehicles. It's support for active tests that you need.
Anyway, what I said about firmware is still true. The first cable I bought from Amazon with firmware 1.4 did not let me access the brake bleed utility. The 2nd cable I bought from Aliexpress with firmware 2.0.4 let me do so.
Hi
I found this post when looking for a proper mini vci cable.
I need to do key and TPMS programming.
A questions just to clarify: Does original XHorse suport ECU flashing? Can anybody confirm?
P.S. I was about to order the 2.0.4 mini vci for $32 from the link you posted but then I read the feedback comments there and specifically the answer from the seller to the comment of Canadian guy I decided that I better find another seller, so I did and it is cheaper ($25)
I ordered it today and will post my results (and the link) once I receive it.
Hi
As far as I know the pressure in tires is OK, so I want to do some diagnostic. I plan to see sensor readings with TechStream to see if one of the sensors is malfunction. Then buy a replacement and program it.
