CT 200h Model (2011-2017)
What do you guys get on miles per tank?
Old 12-12-19, 04:18 PM
  #61
Raidin
Raidin's Avatar
Originally Posted by E46CT
I know this quote is three years old... but that's pretty interesting. I wonder if there's any downside to topping the tank off. I never tried looking into it but our tank is on the small side and a little extra range (say 1 gallon extra instead of your 3) would be awesome if it doesn't hurt anything..
And yes the theoretical range on our cars would be best at full 50 mpg (about what our cars can do on highway) x the # of gallons in the tank. I always get about 50-52.5 on highway. 55 if i REALLY try and don't exceed like 60-65
My car is lowered too so theoretically that should help. an inch lower on all four corners is a total of four inches of tire the wind doesn't have to slice through. So at a 7 inch wide tire x 1 inch that's 28 square inches of rubber. And that rubber is rotating further adding resistance (probably)
It will hurt the car to top off if it's done regularly. I tried it for one week straight as a test. I was surprised I was able to add 3 gallons after the pump clicked the first time...
Old 12-13-19, 08:04 AM
  #62
E46CT
E46CT's Avatar
Received 2,220 Likes on 1,660 Posts
I'm sure there's some buffer built in though. 3 gallons is a lot. you are a brave man.
I think though they wouldn't make it to where the car will damage itself if you happen to go half a gallon over the first click. in our cars, a half a gallon is quite a bit of range. Can mean the difference between getting stranded and not. That's up to 25 miles highway range. I think i may be tempted to add a 1/3 to 1/2 gallon.. lol. maybe i'll look into how our tanks are actually constructed since i'm sure every car has a different threshold to where this is acceptable and not. I do wish our tanks were bigger. I wonder if Toyota designed them EXTRA small on purpose so the perceived "yeah my prius only takes $XX to fill up" is more impressive.
So this is our fuel tank. I guess the idea of not topping off is to 1) allow gas a place to expand and 2) prevent liquid from being siphoned up that green thing (the vent tube for vapors). So looking at this, I don't think a half a gallon will hurt anything. Likely 1 gallon extra is OK too.
I'd probably just drive extra gentle the first 25 miles
Now as for the gas pump itself, who knows whats going on if you fuel after it clicks. Would have to pay attention to the range meter to see if it goes up with the extra gas after first click. Some websites say the extra gas is returned thru the pump.
mujilim (12-25-19)
Old 12-13-19, 08:38 AM
  #63
Raidin
Raidin's Avatar
When I filled up to the brim, I am talking about filling up to the cap.
Also, there's a system to capture gasoline that's evaporated for emissions reasons. This system will be overloaded if there's a lot of excess fuel from overfilling by a lot. That's the system that can fail if one were to do this regularly.
mujilim (12-25-19)
Old 12-13-19, 08:47 AM
  #64
E46CT
E46CT's Avatar
^ya i just said that lol. apparently the green thing which is where the vapors go. see pic above. The idea of not overfilling is just to prevent liquid from being sucked up thru that tube and into the recovery tank which is a charcoal tank. but i don't see 1/2 a gallon causing much rise in a "11 gallon" tank. Maybe not a habit.. but in a pinch when you need extra range.
Raidin (12-27-19)
Old 12-25-19, 07:37 PM
  #65
mujilim
mujilim's Avatar
Default fuel comsumption 15.7 km/litre on 2011 ct200h old gen
hi forum
i using a 65000km 2011 ct200h . it low mileage compare to the year of age . but i looking for opnion as servicing still not due for me but i looking to fuel econ on eco mode not normal nor sport mode it drink 15.7km/l litre (based on the indication since i dont have trip A/B shown on std model ct200H) on 98 octance petrol i considering a send in to agent for a servicing to see if it can reduce my fuel consumption by doing addtional engine air filter and spark plugs change with 65000km ./40k miles servicing since both 57000/35k mile maintance schedule dont indicate filter or plus changes . . i wonder does anyone has similar experience wheather it worth to try
Stage3
08-10-23 05:40 PM
ATLs400
08-29-19 05:17 AM
semar
06-22-16 09:42 PM
pemarsh
LX - 3rd Gen (2008-2021)
15
06-10-08 08:29 AM
gsWarrior
Maintenance
06-01-05 03:10 AM
Quick Reply: What do you guys get on miles per tank?
