CT 200h Model (2011-2017)
Camber, Caster, Toe Specs
Old 02-12-16, 12:44 PM
Negative1
Negative1's Avatar
Default Camber, Caster, Toe Specs
After replacing the factory tire at 50k miles and an alignment to verify everything is still looking good, I feel that my car does not handle as good as it did before I replaced the tires. I replaced the tires with factory Michelin's and I've had the alignment check multiple times (at 2 different places), but it still doesn't handle well.
Are alignment rack's ever re-calibrated?...or have a calibration period?
I have a '12 F Sport SE, are the camber/caster/toe specs different from a base model?
This is from the print out that I got from my 1st alignment:
Spec Range
Front Camber -1.0 to 0.5
Front Caster 5.1 to 6.6
Front Toe 0.00 to 0.20
MIC123321
08-23-15 08:39 AM
doodoo
11-14-14 04:26 PM
iSexy
Suspension and Brakes
10-30-12 07:24 PM
Phanatik
06-13-07 10:38 PM
Kharizma
04-29-06 01:32 PM
Quick Reply: Camber, Caster, Toe Specs
