CT 200h Model (2011-2017)
P0A7F – Hybrid Battery Pack Deterioration in my 2011 CT200h
Old 01-01-17, 10:31 PM
  #31
sheiksoft
sheiksoft's Avatar
Originally Posted by kt2012
just unplug the -ve for about 3mins and the check hybrid error code will be reset. just need to retune radio stations and clock if it runs.
but getting tech stream would be easier. anyone have a reliable source ?
Yes, I am doing like this for the past couple of months, unplug-replug 12v for resetting the error code.The mini vci cable I ordered from Aliexpress is taking some time to reach me.
Old 01-03-17, 01:07 AM
  #32
kt2012
kt2012's Avatar
maybe rebalance the battery first? i have hyperion charger. was wondering if could charge afew cells individually at the same time using balance charging function. got to read up.
sheiksoft (01-04-17)
Old 01-04-17, 12:45 AM
  #33
kt2012
kt2012's Avatar
saw suppliers selling Prius batteries from $0.10-50 ? wonder how much for 28 pcs. what do you guys thinks about alibaba
eg
https://m.alibaba.com/product/604282...0312.27.7OuZyZ
Old 01-04-17, 11:07 PM
  #34
sheiksoft
sheiksoft's Avatar
eg
Oh thats nice. They seem to be dead cheap price wise. Anyone has experience with Alibaba.? May be it comes with no charge and we have to boost the charge.?
Regarding my car, it doing good without any DTC. Some times the battery icon spikes and comes back to normal. I will look about balance charging. Thanks for the info and link.
Old 01-05-17, 01:28 AM
  #35
kt2012
kt2012's Avatar
wrote a small excel spreadsheet comparing cell average to the pack average.
highlights potential cells that might be causing issues.
takes the guess work out of looking at numbers.
sheiksoft (01-08-17)
Old 01-25-17, 10:13 AM
  #36
kt2012
kt2012's Avatar
Default mini vci arrived
monitored and tested the batteries while charging by ICE
looked fairly balanced.
but under load issues with modules 4 to 9
will be taking these out to rebalance/refresh/cycle with a hobby charger.
could see while running Techstream the uneven discharge from affected cells.
many videos on YouTube on how to cycle nimh batteries.
got my replacement cells from Ebay just checking them out. looks good.
sheiksoft (02-08-17)
Old 01-25-17, 07:37 PM
  #37
roadfrog
roadfrog's Avatar
Alibaba is China's version of Ebay and the largest E-commerce company in the world....larger than Ebay and Amazon combined. I've heard good things about them, though I've not yet dealt with them. They are HUGE.
Old 01-25-17, 07:48 PM
  #38
kt2012
kt2012's Avatar
got my Prius modules from Ebay US.
Old 01-28-17, 11:54 AM
  #39
kt2012
kt2012's Avatar
Default 1 cycle of charging and discharging
comparison before and after balancing. temperature reduced due to cleaning fan too.
cleaned out cooling fan and temperatures dropped across 3 temp sensors.
Old 02-08-17, 11:50 PM
  #40
sheiksoft
sheiksoft's Avatar
Hello Friends,
Finally I got the Mini VCI cable yesterday from Aliexpress after a long wait of two months. I checked and saved the report as PDF which I have attached with this thread. I will also post some snapshots taken. Please advise me what to do from now on.?
Do I have to drive the car for few miles with the techstream on and monitor the battery module voltage change.? Sorry for noob questions.
Please do review the reports and advise me on how many modules to change. I will order it asap.
kt2012, awesome find and good job on figuring it out & changing the battery modules. You posted the voltages while on load. You just put it to D mode and give some accel to see the voltage changes.? Also could you please provide me the eBay link where you ordered the modules from.? You and me on the same boat. I want to fix this badly.
The below snaps are taken when the car is in Parked mode. I also got C1241 message too.
Old 02-09-17, 02:08 AM
  #41
nacke
nacke's Avatar
You have to discharge the battery to see which modules blocks run out of energy first, as kt2012 did.
And after that one must determine which module of a block is bad (or even both?).
sheiksoft (02-09-17)
Old 02-09-17, 04:03 AM
  #42
sheiksoft
sheiksoft's Avatar
Originally Posted by nacke
You have to discharge the battery to see which modules run out of energy first, as kt2012 did.
Thanks. I will do a drive and record the readings to see which ones are dripping low.
Old 02-09-17, 11:01 AM
  #43
sheiksoft
sheiksoft's Avatar
As suggested I took the readings while on load (while driving). Please review the attachments and let me know how to take it from here. Also I am going to order around 6 modules via eBay.
File Type: pdf
File Type: pdf
File Type: pdf
Old 02-09-17, 07:06 PM
  #44
kt2012
kt2012's Avatar
i could not find any video on how to remove the whole battery pack. only managed to strip the cover off to expose cells for individual cycling. there is one last bolt on the right side i cant access. if i can undo that bolt might be able to remove the whole nimh pack to swap out problem cells.
however given the time consuming process only managed to cycle it once. which is likely not enough. read cycling nimh required at least 2 to 3 times or more.
so my problem is recurring. the one cycle refresh only lasts about a week.
might be faster with a 4 port hobby charger from hobbyking or anyother brands. there are many sellers for prius on ebay just look for those that can ship to your country and ship via USPS.
Old 02-09-17, 07:18 PM
  #45
kt2012
kt2012's Avatar
sheiksoft your lowest modules seems to be 8 and 9. like Nacke mention might be either one or both cells in the modules got to strip the cover and test each module. a time consuming process. you will need some cover to work away from rain and dust and lights if going to work at it in the night. try to be careful with the tiny screws for the cover. thought i lost one under the passenger seats. luckily was stopped by some cables and i could pick up with my screwdriver with a magnetic tip.
need
8mm
10mm
12mm
sockets and a ratchet to make things easier.
remember to remove the orange safety switch before opening up the battery otherwise is 200volts.
sheiksoft (02-13-17)
Quick Reply: P0A7F – Hybrid Battery Pack Deterioration in my 2011 CT200h
