CT 200h Flip Screen not opening/closing
The flip screen on my 2013 CT 200 has stopped opening and closing. This happened when I cut the power while theh screen was part open.
The screen dose not respond to the open /close button and also does not move when reverse is selected/deselected.
dealership says they have never seen this problem but will investigate if I take it in - a round trip journey of 120 miles - maybe require two trips, one to investigate and one to repair.
Does anybody know if there is a fuse for this function or a way to reset?
Can anyone help?
Can anyone help?
Could be a bad ground, or the motor itself could be dead. Also check to see if there is anything of the sort that is blocking it or hindering the mechanism from fully engaging.
CT200h Flip screen problem solved
I disconnected the auxilliary (12v) battery for approx 5 mins and then re-connected the battery. Flipscreen now opening and closing correctly.
Thanks tofuprod for your suggestions.
355F1
04-20-24 08:58 AM
