I've changed the transmission fluid twice, every 60K miles. I also change the brake fluid from time to time and change the coolant and inverter coolant every 100K miles.
Sounds like you should have no issue getting as many miles out of yours as I have out of mine!
I have a 2011 with over 191,400 miles. No issues so far. I change the oil and oil filter every 5K miles and I'd like to get as far as Raidin with over 305K miles...
nice! hopefully i can established that with my car also =)
2012 with 51,000 miles, I have another car that I drive, otherwise mileage would be higher. No problems so far, just swapped out the 12 V battery. Oil, filters, brake fluid change is all I've done so far. Need to change the original ATF when I get the chance.
Are you aware that it is not recommended to change transmission fluid?
