2014 CT200h brakes pads replacement DIY.
Just get OEM pads and they are just like doing any other brake pad replacement on any other Japanese vehicle. The pads last a long long time. When doing the replacement be sure to pull out the 2 slide pins at each caliper to clean and regrease them with SylGlide lubricant. Look at youtube for more data as they are similar to Prius brakes.
I found a seized slide pin on my HS250h at 60,000 miles and I had hardly any pad wear. I was just doing a routine brake service to inspect, clean and lubricate the brakes when I found the problem. It had probably been the cause of my reduced mileage lately.
However you cannot bleed these brakes at home due to integration with the hybrid system. A shop with Toyota Techstream software must do it. Many import repair shops have it.
My brakes are worsen, it will not grab as much as before i replaced them. I replaced the front rotors and pads, I only replaced the pads on the rear. I accidentally leaked some brake fluid on the rear calibers. What do I have to do now? Thank you.
You have new pads and rotors in front, they need to wear in a bit to full grab each other as well as your old brakes. If nothing else is wrong it should improve in a couple hundred miles.
Some pads need to be burnished initially before they work well and all new brakes need a couple of hundred miles to break in and reach full grab force. This means making 4 or 5 hard stops from 40 mph then letting the brakes cool.
Use lots of brake cleaner to remove the spilled brake fluid. It is in spray cans at every auto parts store. I always keep several cans around. It is great for cleaning up other stuff around the house!
Brake cleaner is your necessary friend during every brake job as you always get grease or fluid on something. It helps to always spray brake cleaner on the pads friction surfaces and rotors right before installation and let it dry, which takes about 1 minute. Spray until it runs clean. You may have gotten some on your pads or rotors during installation and may need to go back and spray clean them. Or you may need to have a shop bleed your brakes.
Have you done a brake job before?
I hope you did not over tighten the floating caliper/slide pin bolts as they only need about 25 foot pounds torque.
You'd probably have to disassemble the hardware if you suspect something is up and at that point you may as well clean and relube (if toyota specifies for lube) the pins and reassemble. I doubt thats causing your MPG reduction though.
As far as pads, our stocks are a ceramic or ceramic blend. Which sucks for feel and response. Rock auto sells some metallic blends and I'm tempted to try those. i really hate the spongy feel of our prius pads.
poppe (01-10-20)
poppe (01-10-20)
