Porshe Wheels on CT200H
Has anyone ran porshe wheels?
I'm not too familiar with how wheel/tire dimensions work with offsets and OEM etc.currenlty doing my own research but wanted to start a thread to see if anyone has thought about this before? Thinking about getting these:
Front - Rims: 19x8.5 offset 55 - Tires: 225/35 ZR19
Rear - Rims: 19x11 offset 62- Tires: 315/30 ZR19
From what I understand currently, I don't think these will fit...but am wondering if there are spacers or what my options might be to make them work?
Anyone have an idea if this is at all even possible?
Possibly.
I run 5x130 on my Volvo convertible.
19x8.5 55 offset corrected to 35mm 235 35 19
19x11.5 62 offset corrected to 27mm 265 30 19
you need to get in there and measure the rear.
Im running 17x8.5 with a 35 and the fronts can go more aggressive.
basically you need to call lance at motorsport tech in Reno and get some adapters from 5x100 to 5x130 in 20mm to start for the fronts for sure
The only way I see those fitting is by installing a widebody kit on your vehicle.
dexterco
07-03-14 12:31 PM
