CT 200h Model (2011-2017)
E46CT CT200h Diary (w/ pictures)
Old 02-07-19, 04:58 PM
  #31
codenko
codenko's Avatar
Wow, that button fits perfect. What did you search to find that? I'm assuming there are other Lexus/Toyota models that have the same fitment?
Old 02-08-19, 07:43 AM
  #32
E46CT
E46CT's Avatar
Received 2,187 Likes on 1,641 Posts
It's just an aftermarket button commonly found on ebay or amazon. they make them for the standard size all toyotas and lexuses use. probably the most common car people buy these buttons for are toyota trucks cause people like to mod them. light bars, radios, winches and such.
Old 02-08-19, 07:45 AM
  #33
E46CT
E46CT's Avatar
I thought i updated this thread. anyway turns out the backup camera mod i did won't work as intended. it activates the reverse lights. i'd need to install a bunch of relays for this to work. too complicated. i want to work on another camera solution using a dedicated screen. maybe for the front. this is just for fun though cause i like to create cool/fun/uncommon mods. serves no real useful purpose
Old 02-08-19, 10:32 AM
  #34
KLF
KLF's Avatar
I wish I could figure out a way to manually turn the camera on in my Land Cruiser, it would be super helpful when towing a trailer. I've looked at the wiring diagrams and it's too complicated, I'm afraid of frying something in the head unit on the dash.
Old 02-11-19, 09:14 AM
  #35
E46CT
E46CT's Avatar
you can always just buy a cheap kit on amazon with a small screen and mount it like you would a GPS. can do it under $50 probably
Old 02-11-19, 12:24 PM
  #36
codenko
codenko's Avatar
Have you looked into the beatsonic module for the front camera? I'm sure it'd only require minor modifications to make it work with the reverse camera.
http://www.beatsonicusa.com/cs5ep.html
Old 02-11-19, 12:26 PM
  #37
E46CT
E46CT's Avatar
^interesting. i wonder if its for models with or without nav? or both?
Do you have this?
Basically i wonder if its different for the nav the way its wired. i don't recall my non-nav car having rca inputs or outputs.
Old 02-11-19, 12:36 PM
  #38
codenko
codenko's Avatar
Actually, it looks like it lets you switch between the reverse and the front camera already.
I just ordered one along with the iPhone mirroring kit, but my 2014 has nav. The website seems to denote if factory navigation is required or not, which leads me to assume it might work on Non-Nav models too but I would reach out to BeatSonic to find out.
Old 02-11-19, 12:39 PM
  #39
E46CT
E46CT's Avatar
I'd be more interested if i had a nav screen. The small LCD in the mirror won't justify the cost of this but cool none theless. looking forward to reading your install notes.
Old 02-17-19, 01:15 AM
  #40
E46CT
E46CT's Avatar
Changed the transaxle fluid
Got a 4 pack here (link) Genuine Toyota WS
Exactly 3 full quarts drained out of the drain plug. I added 3 1/3 quarts back. Probably due to spillage. When I opened the fill plug, a little did dribble out. The fluid was murkier than expected at 43,430 miles. 2015 F Sport.
Old 02-17-19, 05:12 PM
  #41
14ct200h
14ct200h's Avatar
How often the transaxle fluid needs to be changed? Was this on the 3rd gen prius?
Old 02-17-19, 05:24 PM
  #42
E46CT
E46CT's Avatar
I don't know. I think Toyota says 100k or 125k. I think 50k is pushing it. its cheap and easy. why not.
i dont get the comment about the prius
Old 02-19-19, 10:11 AM
  #43
RG13
RG13's Avatar
How much power are you running with your audio system? I’ve seen a lot of posts about not exceeding 350 watts RMS or 30A. Also, are the door speakers 6.5” or 6x9?
I’m looking to upgrade my audio system in my ‘15 CT and haven’t seen much of a straight answer in terms of how much power you can practically run on the electrical system.
Old 02-19-19, 10:20 AM
  #44
14ct200h
14ct200h's Avatar
Front door speakers are 6x9. Rear are 6.5
Old 02-19-19, 10:24 AM
  #45
RG13
RG13's Avatar
Thanks. I talked to my local audio shop a while back about their installs in a CT and they said they used 6.5s in the front and back. I’m guessing they used an adapter to fit the 6.5s up front.
Quick Reply: E46CT CT200h Diary (w/ pictures)
