CT 200h Model (2011-2017)
E46CT CT200h Diary (w/ pictures)
Old 02-07-20, 12:43 PM
  #106
E46CT
E46CT's Avatar
Received 2,220 Likes on 1,660 Posts
^they are all over ebay and amazon. they fit other toyota models too which use the same part. corolla comes to mind as well.
Old 02-13-20, 02:30 PM
  #107
E46CT
E46CT's Avatar
Two photos from road trip last week. And I have the chrome grill lower coming in the mail tomorrow. $280 for that brand new from Lexus =/
Old 02-18-20, 07:44 AM
  #108
E46CT
E46CT's Avatar
Installed brand new lower chrome "brightwork" (as they say in england) grill/trim piece from the 2016+ models. $280 shipped from Lexus. Kind of a rip but it's a huge upgrade from painted gray from the 2014/2015 models. I would've liked the black chrome ones indolent has but didn't feel like swinging that kinda dough.
the grill wasn't as easy as i thought. entire bumper had to pull off.. (easy) but the hard part was how the grill was attached to the lower f sport grill. i still don't know how i got the trim piece off. just when you think you've removed all clips and screws, something else is holding it on. it's all layered in a weird way.
nigel821 (09-19-22)
Old 02-18-20, 10:52 AM
  #109
TheRob
TheRob's Avatar
Looks great. So 2016+ all come with the chrome on the bottom? I want to do the same with my CT.
  #110
E46CT
E46CT's Avatar
My CT200h has developed a rapid click sound as I come to a stop with light braking. Maybe from 10-0 mph. The rate of tick slows down as the car slows. Happens only with light brake application. I removed the wheel and inspected everything and retorqued everything. I am suspecting the front strut mount. It started as a light, slower tick, now it's a slightly louder faster tick. May try to sneak a wrench on the top strut nut too
I heard a 3rd gen prius braking in my neighborhood making a similar noise while braking to a stop. Since it uses pretty much identical front suspension, i am guessing it could be a common item.
Old 02-18-20, 10:53 AM
  #111
E46CT
E46CT's Avatar
yes 2016 and newer came w/ chrome. 100% the F sport did (since i owned one) and i'm 99.99% the non f sport did too.
Old 04-14-20, 12:55 PM
  #112
E46CT
E46CT's Avatar
Changed oil again. 5k. K&N oil filter that was super cheap on sale $2 (or was it $1.50--thanks to the person who linked it) and Castrol Magnatec 0W-20 for $16. The amazon oil is $6 more expensive. new crush washer of course.
Old 04-15-20, 08:26 AM
  #113
BirgeyT1
BirgeyT1's Avatar
Did you ever figure this out.? Mine started doing it as soon as I re-installed the suspension after lowering the car.
Old 04-16-20, 08:46 AM
  #114
E46CT
E46CT's Avatar
Never figured it out. Lexus wanted $190 to diagnose it and said if its under the powertrain warranty, they'll wave that diagnosis fee. I may just bite the bullet pay it and have them diagnose it..just in case it turns out to be covered under warranty.
I disassembled and reassembled and cleaned the front caliper and pads. No change. And i've pretty much ruled out the strut or strut bearing. I am thinking the axle. I imagine to find out, they'd have to put it on a lift and brake.. but then the car wouldn't be under load. strange for sure..
Old 07-26-20, 11:31 PM
  #115
E46CT
E46CT's Avatar
Wrapped both front door window control panel in gloss black vinyl. Very happy how it turned out and gives a much more premium appearance and feel. Best of all it was pretty much free as I used left over vinyl scraps from past projects. I even glossed out the parts where you put your fingers inside using inlays.
nigel821 (09-19-22)
Old 07-27-20, 08:52 AM
  #116
HOMER350
HOMER350's Avatar
Looks good. The center console may be a little too much shine but on the window/lock trims works great. I did a matte CF on my last car but did the center console so wanted the matte for there mostly.
But yeah definitely a more premium look to it without standing out too much. We would likely need to remove the entire door panel for the door handle trim im guessing.
Old 07-27-20, 10:17 AM
  #117
E46CT
E46CT's Avatar
Thanks.. Yeah the door handle trim is tucked too tightly to wrap it nicely. I forgot if that plastic trim is plastic welded on but if it is forget it lol. been a while since i had the panels off.
The driver's door window trim is easy it just lifts upwards. however the passenger door window trim takes more finesse, you have to pop off the grippy rubbery textured door handle trim first, then two 10mm screws under that hold the plastic frame door handle, then the window switch trim comes out.
I want to wrap the steering wheel trim next but dreading pulling the airbag. not that its hard, just a PITA to disconnect the battery since the battery is pretty buried.
Old 07-27-20, 11:41 AM
  #118
HOMER350
HOMER350's Avatar
Ah yes the passenger side with that big handle.
I don't remeber what the steering wheel looks like but on the IS that trim will pop off just high enough to allow for wrapping without removing anything. Then its just working around the FS logo.
Old 07-27-20, 06:02 PM
  #119
E46CT
E46CT's Avatar
I need to remove the trim anyway because the trim squeaks when i turn the wheel so i need to remove it to insulate it. been putting it off a year
Old 07-28-20, 03:07 PM
  #120
E46CT
E46CT's Avatar
I am considering getting new OEM floormats for about 120 shipped. I wish I could buy only the driver's mat. I took a steamer and steam cleaner to it and cant get the lexus embroidery white again. plus the mat is just worn out. i guess that's what 5 years of driving does to it.
But kind of a steep price to pay. My other mats are pristine.
Quick Reply: E46CT CT200h Diary (w/ pictures)
