E46CT CT200h Diary (w/ pictures)
#121
I did this a few months ago, but wanted to update.
I cut out some sturdy reflector tape and attached them to the doors. This is a good safety upgrade as our cars do not have any warning lights. I would like to add some actual lights and have some clean OEM type lights.. just dread pulling off the door panels. This will do for now! I cut them to shape using scissors so they're not 100% straight but good enough.
Vegasaurus (08-26-20)
#122
only car ive ever owned which didnt have them or a light.
ThomasD94 (08-07-20)
#123
Yeah. it's just cost cutting by lexus. wiring up some lights shouldn't be that hard.. just kind of challenging to find a solution that would look factory. I spent like half an hour combing through ebay seeing if i can mash something together.. i found a few items but wasn't quite confident it would look right. For now this is cool. don't have to cut anything up!
#124
Updated photos. Rear wiper delete using Mazda 3 rear wiper delete kit (It was only 10 bucks) i wish i had gotten the one for the Prius though which is a bit larger and correctly sized. Water tested and no leaks. But it's barely barely big enough. Like by a hair. The seal barely covers the hole. If anyone does this get the correct 1 3/8" cap/cover kit. you can also use generic plastic caps and silicone around it too. The size is 1 3/8". You can get them at home depot or on ebay. they're plastic caps. I did this method before on my Prius.
#125
I have a 2019 CT 200h (with tech and premium pack) if you wish to see my car.
#126
Was playing around with some vintage (1960s) photography equipment and wanted to snap a quick shot. Didn't have any updated photos with the new grill piece.
The following 2 users liked this post by E46CT:
Raidin (08-12-20),
Vegasaurus (08-24-20)
#127
I removed the CF vinyl eyebrows. They look a bit cleaner without them, but on the other hand I kind of miss the little bit of personality and uniqueness they brought. I have more gloss CF wrap ready to go so just thinking about it for now. Anyone else wrap their headlight corners like i did? i know one person did it but forgot who.
#129
They should be the same and fit just fine. Why wouldn't they be? If they have orange side reflectors, then you know you're good. It's not like there were any options or changes in the head lights, other than one version being halogen and one being LED. Other countries wouldn't have the orange reflector, and would have a reversed output for RHD.
#130
#131
By "xenon" do you mean HID or LED? My understanding is that there was never a CT that had HIDs from the factory. Just base halogen lights, or LED lights. I believe that both options were available everywhere. However, looking at the back of the head lights, they have different connectors for the low beams. So you would have to do some wiring to swap connectors.
#132
tried to see if I can find a junkyard over there lol
E46CT (08-25-20)
#134
HIDs use the xenon bulb. But that’s what I’m trying to figure out How are the connectors from the Hawaii ct200h than the regular US model. Not understanding how those two can be different yet are technically for the same US market. I understand the euro/jap ones are different connectors. But why did Hawaii get those headlamps as well?
TobiasSing (08-25-20)
#135
Either would have different connectors from the other.
