CT 200h Model (2011-2017)
Front bumper fender assembly question
Old 12-29-18 | 09:31 AM
camiel76's Avatar
camiel76
Default Front bumper fender assembly question
See picture below.
Issue is that the part on the left (with the screw) is still in tact.:
53879 in this overview: http://www.japan-parts.eu/lexus/eu/2...er-stay#52197E
My question is: what is the part in the red circle that is attached to the bumper where the part above needs to be clicked in or anything like that !??
Is that available so that I can repair this myself?
Old 12-29-18 | 05:51 PM
eddie25's Avatar
eddie25
That is indeed what the clip gets clamped to, but I don't know if it's replaceable or not. Good luck.
Old 12-30-18 | 02:32 AM
camiel76's Avatar
camiel76
I found a bit more clue 😀.
This photo from a diy grill change. That small white plastic part, mine seems a bit broken at the bottom compared to this one. it seems the retainer needs to slide of this part so it clicks in.. I will try if I can click it back in somehow..
Old 12-31-18 | 09:22 AM
eddie25's Avatar
eddie25
I just looked at mine. It appears the part it clips on to is part of the quarter panel, so that's a bummer. Hopefully there's still enough there to clip on to well enough.
Old 12-31-18 | 09:49 AM
camiel76's Avatar
camiel76
Thanks for your attention.. I will check it tomorrow.. and let you know.. Happy New Year!! 👍🏻😀
Old 12-31-18 | 11:44 AM
E46CT's Avatar
E46CT
It's part of the bumper. try bolting it on as best you can. should be fine.
if not, not a big deal. all it does is hold the fender liner. you can repair the tab if you want by folding some aluminum or steel over it (use snips to cut it out of a soda can, drill a hole)
you can get clever. can also use fiber glass for a more proper fix.
Old 01-01-19 | 09:46 AM
camiel76's Avatar
camiel76
Result was better than expected...enough to secure the screw again..
yoyofish
RX - 4th Gen (2016-2022)
08-09-17 11:34 AM
Lveyolfe
01-27-17 03:35 PM
greg3852
12-25-15 09:25 AM
bogohead
02-21-12 05:42 PM
