CT 200h Model (2011-2017)
CT200h F Sport mechanical differences and model year structural differences
Old 02-11-19, 09:47 AM
E46CT
E46CT's Avatar
Received 2,220 Likes on 1,660 Posts
Post CT200h F Sport mechanical differences and model year structural differences
OK thought I'd put together a small list of differences for the CT200h F Sport based on parts diagram. This is aside from the obvious appearance/option differences. Apparently the F Sport has 73 unique parts, most appearance, trim/associated fasteners, etc.
The F Sport has the following unique mechanical parts:
Springs (Height is same, but rate is presumably different)
Dampers (Presumably firmer)
Rear Sway Bar (Presumably firmer) w/ associated bushings
Brake Booster (Presumably sportier?)
Pedal Travel Sensor and Pedal (after 2/16) this one is interesting. Don't know what it would do. Perhaps recalibrated? Also interesting it's introduced at a later date.
Steering Control Module (Presumably sportier steering/recalibrated?)
And model year differences for safety/structural enhancements for MY 15 cars:
A-Pillar Door Hinge Inner Reinforcement (for small angle crashes)
Center crossmember at the floor (not sure why this is different for 15, but it is) Can presume it's for general structural rigidity, but it is an odd update, but one nonetheless. It goes all the way across the car in the center.
Also I do not see a difference between F sport suspension parts prior to facelift.
I do see 2014 (all models) got a revised top strut nut. Not sure why.
Engine Differences through the years
2014 saw a revised intake manifold.
2014 saw revised pistons
2015 saw revised piston ring sets (to protect against oil loss and blow by)
2015 saw revised intake cam gear to reduce rattle on startup
The following 3 users liked this post by E46CT:
fiveainone (02-11-19), Raidin (05-10-19), TobiasSing (07-21-20)
Old 02-11-19, 09:42 PM
fiveainone
fiveainone's Avatar
Second post from this thread got some info from the website for pre-face lift models, mentions only damper differences and not springs:
https://www.ct200hforum.com/forum/le...uspension.html
Don't know if it's the same for 14-17, but with the minimal amounts of changes for this car, maybe it's the same?
Old 02-11-19, 10:37 PM
lexusrus
lexusrus's Avatar
I remembered looking at the small overlap crash tests performed better with the later models with additional structural reenforcements on the driver side. 2014 and later ???
Notes: If there's more, I'll update. If you know more, feel free to add.
Old 02-12-19, 07:53 AM
E46CT
E46CT's Avatar
The F Sport (stock factory) springs have their own specific part number.
2015 MY with build date of 9/14 and later.
Old 05-10-19, 03:40 PM
E46CT
E46CT's Avatar
I added some info I found on Prius forums.
2014: new pistons
2015: new piston rings and new intake cam gear
post 1 modified.
So if you want the latest and greatest powertrain, go for a 2015+.
JasonJi
05-10-19 09:20 PM
LexLuthors
10-04-15 08:20 PM
kevinm123
03-23-15 12:27 PM
Nauticalx
02-21-07 10:56 PM
Quick Reply: CT200h F Sport mechanical differences and model year structural differences
