Need Help Finding a Small Part
My CT200h (2013 model) is missing a screw cover and the liner/carpet-like material for the driver side seat compartment. At the moment, its just the plastic exposed along with a screw.
Here's a picture of the compartment if you are confused to what I am referring to (circled in black) - https://imgur.com/ww2mJnh
I'm guessing it's the same part as the rear driver-side door as that also has a door compartment. It's two small parts at most, but I can't find anywhere to identify what it is called or the part number.
It's literally just the screw cover I need (since I see an exposed screw) and then the carpet-like material/liner.
I think I may have found the part number. I’m also missing this on my CT, so if anyone can confirm this is the correct part number. It’s hard to tell with the diagram on this part site. I’m pretty sure this it though.
74222-76010
74222-76010
Am I wrong in that there is also a screw cover? At the moment, I see an exposed screw, and I thought there' like a plastic plug piece that covers it, then you put the above linked part on top of it?
Mine has the screw exposed as well. I don't know if there is cover for the screw. If there is, I'm missing that too. I don't think there is a cover for that though. I'm looking into it now to see if i can find anything on it.
