CT 200h Model (2011-2017)
Courier CT hits 500,000 mile milestone
Old 11-19-19, 09:42 PM
  #31
TheRob
TheRob's Avatar
I have to say I’m really impressed how immaculate your CT looks with that many miles on it. Looks really good. Has the hybrid battery ever been changed or is still the original one that came with the car? What is your all time MPG average?
Raidin (11-28-19)
Old 11-27-19, 03:22 AM
  #32
phillymac
phillymac's Avatar
That is a awesome looking vehicle with over 500k!!! Congrats! I know I will never keep a vehicle that long but I am still in awe!
Raidin (05-20-20)
Old 11-28-19, 11:39 AM
  #33
Raidin
Raidin's Avatar
Thank you! The hybrid battery AND 12V battery are both still original.
I use Fuelly (my signature) to tally up my MPG, so I assume 47~ is my all-time average MPG. I change speeds and tires brands/models from time to time but I try to drive economically so that sounds about right.
Thanks! It may have over 500k, but it is only 5 years old, garaged 70% of the time, and driven / parked / maintained / repaired carefully.
internalau (02-05-20)
Old 12-04-19, 01:59 AM
  #34
K3RRYB
K3RRYB's Avatar
Thanks for sharing!
what was your maintenance routine?
oil change interval time on which oil?
tranny fluid?
coolant?
Old 12-04-19, 08:42 AM
  #35
tofuprod
tofuprod's Avatar
I miss my old CT but I still ghost this sub-forum even nearly a year + later. I loved it so much in fact my good friend ended getting one for himself and he loves it too. I remembering mentioning to him about your feats with the CT; and as can be seen.. still is doing awesome.
Nice work on the detail, as a guy who used to do a lot of this on the side, it's not always the easiest feat.
Raidin (05-20-20)
Old 01-06-20, 06:11 PM
  #36
btc13
btc13's Avatar
So youve driven 500K miles on original conventional battery and original brakes? Seems pretty far fetched, no offense. Must be in a warm climate and highway miles, but then howd you average 47mpg on the life of the car?
Old 02-24-20, 11:27 AM
  #37
Fred2726
Fred2726's Avatar
How do you like the Falken Sincera SN250 tires? @Raiden
Old 02-24-20, 12:26 PM
  #38
E46CT
E46CT's Avatar
Received 2,158 Likes on 1,621 Posts
I'll vouch for him. He's not one to lie.
Battery life isn't really measured in miles, but in time. Typically, discharge cycles. Since Toyota has excellent battery management and Raidin does almost all highway (if not exclusively highway) it's not "far fetched" to have his battery run this long. It's pretty common. Check out any 3G prius forum.
Same goes for the brakes. If you manage the brakes well AND drive highway, you really shouldn't need brakes very often, if at all.
As far as highway, when I do long trips in my F Sport, i've gotten up to 53-55mpg before on 200 mile round trip all highway. Multiple times. I can get about 50.0 mpg even without trying, w/ AC on, averaging about 70-72 mph.
So 47 mpg, loaded up w/ cargo, highway, is pretty doable.
internalau (02-27-20)
Old 02-27-20, 09:29 AM
  #39
humbak
10th Gear
humbak's Avatar
Originally Posted by Raidin
I'm not convinced the EGR system is why HGs go, but the only issue I had was the intake manifold getting clogged up.
So far, the engine is completely original outside of the gaskets and elements that get changed along with it, and the water pump and valve lifters (I think?) which have been replaced with new OEM parts.
I have no plans to maintain the EGR system outside of doing the same thing should the same problem come up again.
Well, once you wrote that you had a cooling fluid dropped.
https://www.clublexus.com/forums/ct-...l#post10057666
After ca 15k third problem revealed.
Could the overheating of the engine cause the HG failure?
Old 02-27-20, 09:48 AM
  #40
E46CT
E46CT's Avatar
Overheating is usually *THE* way the headgasket goes. The headgasket gets scrubbed or the head and/or block warps causing the seal to break. This goes for any car, but particularly cars w/ longer blocks (inline designs)
typically V6s and V8s are less prone to HG/head damage when overheated vs an I4 or I6.
Old 02-28-20, 12:10 AM
  #41
humbak
10th Gear
humbak's Avatar
So, @E46CT , will you recommend monitoring the coolant / oil temperature to avoid overheating?
To be honest i have blown HG once in my first car, overheated
Now I use OBD adapter and android app for temp control.
Old 05-16-20, 01:17 PM
  #42
Khaotic
Khaotic's Avatar
I'm very curious as to what your mileage total is now? Have you hit 550K yet?
Old 05-19-20, 10:05 AM
  #43
E46CT
E46CT's Avatar
Nah I wouldn't worry about it personally. Even with the BMW E46 which is probably the #1 car in the world prone to overheating resulting in a blown engine, I never worried about it.
Old 05-20-20, 08:36 AM
  #44
Raidin
Raidin's Avatar
564,xxx right now.
The following 3 users liked this post by Raidin:
All4Lexus (05-20-20), Khaotic (05-20-20), MysteryT (09-13-20)
Old 05-20-20, 05:10 PM
  #45
Khaotic
Khaotic's Avatar
564,xxx right now.
That's some strong mileage that even I will not reach. The highest mileage car for me was 412K when I sold it.
Raidin (05-20-20)
Quick Reply: Courier CT hits 500,000 mile milestone
