CT 200h Model (2011-2017)
Courier CT hits 500,000 mile milestone
Old 05-21-20 | 12:16 AM
  #46
Raidin's Avatar
Raidin
Originally Posted by humbak
Well, once you wrote that you had a cooling fluid dropped.
https://www.clublexus.com/forums/ct-...l#post10057666
After ca 15k third problem revealed.
Could the overheating of the engine cause the HG failure?
I missed this.
The coolant issue was when the coolant was leaking into the cylinders when the HG blew. Right before this, I had a coolant leak due to a piece of debris taking out a coolant line under the car, which could have been the underlying reason for the HG failure, though it is a known issue for this engine.
Old 05-21-20 | 12:31 AM
  #47
Raidin's Avatar
Raidin
I don't know how I missed all of this. The thread did not show unread replies till only recently. Sorry guys.
Originally Posted by K3RRYB
Thanks for sharing!
what was your maintenance routine?
oil change interval time on which oil?
tranny fluid?
coolant?
Oil change: every 15,000 mi
Engine air filter: every 50,000 mi
Cabin air filter: every 50,000 mi
Engine coolant: every 100,000 mi
Inverter coolant: every 100,000 mi
Transmission fluid: every 100,000 mi
Spark plugs: every 120,000 mi
Oil: Mobil 1 Extended Performance 0W-20
Oil filter: Wix 57064XP
Originally Posted by tofuprod
I miss my old CT but I still ghost this sub-forum even nearly a year + later. I loved it so much in fact my good friend ended getting one for himself and he loves it too. I remembering mentioning to him about your feats with the CT; and as can be seen.. still is doing awesome.
Nice work on the detail, as a guy who used to do a lot of this on the side, it's not always the easiest feat.
Thank you. The detail job was done by a friend who has all the gear. He did a great job, I agree.
Originally Posted by btc13
So youve driven 500K miles on original conventional battery and original brakes? Seems pretty far fetched, no offense. Must be in a warm climate and highway miles, but then howd you average 47mpg on the life of the car?
Not offended at all. If by conventional battery you mean the 12V battery, then yes. They last 5 to 6 years typically and mine started to give out recently, so I replaced it. It was after 500k miles, but I forgot to enter it into my log so I have to go get that info and update later.
If you meant the hybrid battery, that one is designed to last around 10 years, and I have not had any issues. It still charges and discharges to proper levels, and has not given me any error codes.
Front brakes did not last 500k miles, they were replaced, along with the rotors, at 335k miles. Rear brakes almost did though, as I had them replaced at 495k.
I work in the Houston, Texas area, so warm weather is typical for nearly the entire year. I also drive on cruise control at 60 MPH on 95% highway, 5% city roads. I normally see 45 MPG to 52 MPG, which is why I am able to average 47.
Originally Posted by Fred2726
How do you like the Falken Sincera SN250 tires? @Raiden
They are not as great for fuel economy, but they are very good tires otherwise. My new ones are General Altimax RT43, which are also very good so far.
sh13 (08-21-21)
Old 08-24-20 | 03:29 PM
  #48
Vegasaurus's Avatar
Vegasaurus
congrats and thanks for sharing as always!
Raidin (08-25-20)
Old 08-30-20 | 11:01 PM
  #49
jjchicago's Avatar
jjchicago
Originally Posted by Raidin
The plan is to keep it as long as I can. You never know when I may end up changing jobs, the car might die, get totalled, or maybe I may find a need for something else and have to switch. So far, so good. It has survived daily highway driving with debris and trucks trying to destroy it, lol, a few hit and run wrecks, a few windshields having to be replaced, two major repairs resulting from the two major issues with this engine at high mileage, and a few high-water situations during some of the bad flooding we get in the Houston and Galveston areas here in Texas.
I would love to get the new Rav4 hybrid, and would also love to get the Rivian R1S when it comes out late 2020/early 2021, but right now, it has done everything I've needed it to, so I want to see how far I can push it.
As far as pictures... I really wanted to take a few but the car is dirty because the plan was to detail it at 500k. I found out that a friend does this himself and is offering to do it for me at his home. I'm going to see him soon and get a quote to compare to a detail shop I spoke to before. After that, picture time!
Did you replace or fix the hybrid battery??
Old 08-31-20 | 10:50 AM
  #50
jjchicago's Avatar
jjchicago
Deleted post
Old 09-01-20 | 12:11 PM
  #51
Raidin's Avatar
Raidin
Nope. It should last 10 to 12 years on average regardless of miles. No issues so far, 6 years and 588k miles later.
Old 09-01-20 | 03:06 PM
  #52
E46CT's Avatar
E46CT
Your car has traveled 10x the amount mine has. I have 58,000 miles. lol - 2015 F Sport
surprised you're on original wheel bearings. post some update pics, tire pics. would be interesting to see. I bet if you make it to 1,000,000 miles, lexus will give you a call and buy you a new car
Raidin (09-03-20)
Old 09-03-20 | 09:59 AM
  #53
Raidin's Avatar
Raidin
I will do it at 600k! My General Altimax RT43 should be around 40k miles by the time I hit 600,000.
I don't know much about the technical details, like wheel bearings, but I'm glad everything seems ok so far. Everything on the car is original minus valve lifters (replaced only because 4 were showing signs of wear and they're cheap), water pump (replaced proactively due to rumors it fails early and intermittently without warning, but was still running), one coil (seal was accidentally removed during a test and water was able to get inside during an engine bay detail), and the intake manifold (replaced under TSB after one of the two known defects with the engine design hit me). I think that's it, but I remember more, I'll post it.
Trexus (09-14-20)
Old 09-13-20 | 12:58 PM
  #54
jjchicago's Avatar
jjchicago
Did you replace the tires? If so, what mileage? 🤔
pkim1078
LX - 3rd Gen (2008-2021)
18
11-21-17 12:20 PM
Raidin
12
09-24-17 09:18 AM
Matsui
GX - 1st Gen (2003-2009)
08-07-16 06:45 AM
jagtoes
ES - 5th Gen (2007-2012)
08-15-15 05:41 PM
shikbas
04-11-15 02:29 PM
