passenger door handle problem
Hi all, just recently got a problem with the passenger outer door handle, I can't open the door from the outside, but it will open from the inside, its like something as either broken or disengaged itself ,has anyone had the same problem, if so, is it an easy fix, and how easy is it,getting the door card off, thanks Ian.
door panel is easy like any other car except for the grab handle. use some thin plastic pry tools for it or you'll ruin it.
as far as the exterior handle, you'll probably need a new handle but go inspect it first. time to play detective. don't know until you open it up
Dougg62
01-01-12 02:24 PM
