how to replace your window on your ct200h video
Sucks did someone break into your car?
Gladly the procedure is pretty much the same as all other cars.
Pop door panel
roll down window until two holes in door align with screws that hold window. unscrew old window
Vacuum glass.
slide in new window from top, bolt in
carefully replace /reseal plastic vapor barrier (not only to prevent moisture but this part on many cars is crucial to the airbags going off properly due to pressure sensors) *not sure if this is the case for the Ct200h*
reinstall door panel =)
i've replaced a few windows in my day from cars being broken into. luckily i can now live in an area where it's not very likely.
Pop door panel
Vacuum glass.
danlnyc
GX - 2nd Gen (2010-2023)
54
10-06-16 07:20 PM
