headlight bulb change
Hi All, I need to change a passenger side, head light bulb, is it a easy fix,or is it a job, for the Lexus dealer, many thanks Ian.
It is an easy fix to remove/replace head light bulb. The tricky part was to remove the top black plastic panel to access it. There are approximately ten round fasteners holding the panel, all you have to do is to push onto the top of each fastener then pull to whole rivet pin to remove. I replaced the headlight bulbs with LED Headlight Bulbs CREE-Chips MINI Size 12,000Lm 6000k AUHDER All-in-One Super Bright Conversion Kit. Hopefully, won't need to change bulbs for a long time.
