Any 2013's with engine knock after cold soak?
The Lexus service bulletin about a loud engine knock or rattle noise at initial engine start after cold soak applies to 2011-13 models built prior to a production change in the intake manifold. Even though the VIN of my car indicates that it was built after the production change I have experienced the engine knock on initial start occasionally. The engine knock seems to be correlated with having parked the car just after the engine has warmed up enough for the car run on the hybrid battery.
I'll mention this problem when I bring the car in for its first oil and filter service in a few weeks. I'm interested in knowing whether any other 2013's with VIN JTHKD5BHD2131695 or above are having this issue.
Thanks for posting. I sent an e-mail to my Lexus service advisor to see if I need to bring my CT to the dealership.
My cars vin is prior to the one listed in the bulletin, but I did have this happen to me this morning. My wife came running out to the garage to see what the noise was. Scared me to death!!! After about 15 seconds of shaking and knocking it ran and started normal the rest of the day. Figured it was due to a 3 degree morning and the car setting for a couple of days.
Thanks for posting this and a copy of the TSB!!! I'll be contacting Lexus about this.
Took my car to the dealer today. They said they had not heard about this issue on the CT. I told them that there was a TSB about the problem and that I could show them a video of what the car did at start up (found this on another forum). Well...they are ordering the parts and will fix it next week. They said this is the first one that they have done. Thanks again for posting this!!!
I had this horrible noise a few times. I brought it to the dealer back in December and luckily they were able to duplicate it once. They tried to reproduce it for several days but were unsuccessful.
It seems in addition to the manifold TSB there is another TSB describing similar noise due to a bad rear engine mount. The tech was convinced that the cause in my case was the engine mount. They replaced the engine mount and the noise has not recurred.
JR
JR
Took the car to the dealer today and reported the noise. Turns out that Lexus Canada has a bulletin on the issue: L TCI 3172. Unfortunately, I haven't been able find it on the Internet. A new intake manifold has been ordered and will be installed in a couple of weeks.
Based on the information in the US service bulletin it appeared that my car was built after the production change in the manifold design. It looks like the production change did not affect some/all CTs bound for Canada.
How does the TSB actually work? I live in a very mild climate yearround so I don't think I will ever get a cold soak regularly, although ski country is a few hours drive. Even if I have one of the bad intake manifold's, I don't think I would trigger a trouble code without the cold soak. So can I insist that they change out the part or do they have to pull the DTC first before they can act? I have a tendency to keep my cars long term and my fear is that when I do travel to a cold area that this could be damaging later.
If the code doesn't show up on your car, but it was built prior to the production change for US models, your dealer may be willing to replace the manifold as a preventive measure. Let us know what happens.
It's visible from the outside on a plaque at the bottom of the driver's side of the windshield. It's also on the driver's doorjamb and should be on your vehicle registration document.
I took my CT to drain and replace my transmission fluid (have over 60K miles) and I left my CT overnight so the technicians can check to see if there is a noise after it sits for some time. Low and behold they were able to confirm the noise.
Longo Lexus will be replacing the intake manifold at no charge which is awesome. They gave me a 2014 IS 250 loaner and I should be able to pick up my CT later this evening or tomorrow.
Lexus is doing an awesome job...
