Drag Strip Discussion about Lexus straight line racing on the 1/4 mile, 1/8 mile and top speed flats.
IS350 0-1/4 mile
Old 04-12-06, 06:38 AM
Mr.LS400
Mr.LS400's Avatar
Default IS350 0-1/4 mile
hi guys, i hope that someone knows about the IS350's performance. in how many seconds does the IS350 accelerate from 0-1/4 mile? thanx
Old 04-12-06, 07:12 AM
mort
mort's Avatar
Car & Driver did 13.7sec
Old 04-12-06, 07:18 AM
NotFatBoy
NotFatBoy's Avatar
many people here who have taken their car to the drag have reported real world times between 13.3-13.7
then are those who cant smash the pedal properly who are getting 13.9-14.1 (odd, seeing as how it is an auto)
Old 04-12-06, 07:35 AM
Ramon
Ramon's Avatar
There's a lot more to your times than smashing the throttle. Just to name a few...
Ambient temps
Engine temps
Amount and type of gas in the tank
Driver weight
How well the track hooks
Tire pressure
Old 04-12-06, 07:38 AM
4TehNguyen
4TehNguyen's Avatar
some people got 13.3ish on 29 psi, VDIM off
Old 04-12-06, 08:22 AM
Lets Drive
Lets Drive's Avatar
Ambient temps
Engine temps
Driver weight
Tire pressure
Tire selection & weight
wheel size & weight
Elevation
Old 04-12-06, 08:46 AM
IS350spBLK
IS350spBLK's Avatar
Ambient temps
Engine temps
Driver weight
Tire pressure
Drivers wieght? You'd really have to be up there to effect it, like really up there....
Old 04-12-06, 09:10 AM
al503
al503's Avatar
Brake torqueing
Old 04-12-06, 10:34 AM
NotFatBoy
NotFatBoy's Avatar
Ambient temps
Engine temps
Driver weight
Tire pressure
I was being a bit sarcastic. I understand all the different variables
Old 04-12-06, 10:50 AM
y2ks2k
CL Folding Freak
y2ks2k's Avatar
What’s good about the IS350 with an Auto is that it should pull a 13.7 almost every single run bt almost any driver. Unlike my old Sti that you would be lucky to hit a 13.3 if all things are working for you... good launch... proper shifting, no bog of the turbo because of itall. Same thing with my old S2000... you had to be real damn lucky to hit a low 14. When I dragged it, I could get a low 14 some times but there would be a lot of high 14's in there for various reasons.
Old 04-12-06, 11:18 AM
dnszoom
dnszoom's Avatar
You're right about that! My worst run (last weekend, yes it was cool out) was a 13.69. Because it's an auto, it's easier to get consistent results. Of my 12 runs I believe 9 were between 13.36-13.59.
Old 04-12-06, 01:48 PM
Payam
Payam's Avatar
Well not really, if someone weighs 120lb and someone else weighs 220lb, there is a big enough margin there to see a difference.
Old 04-12-06, 02:02 PM
Badman Forever
Badman Forever's Avatar
the fastest 100% stock is350 i've seen on clublexus has run 13.60x so far. anything faster has some type of small modification.
Old 04-12-06, 02:10 PM
diabelek05
diabelek05's Avatar
Yeah i can say that to STI are very difficult to lunch good, always when my friends would try to be stupid in my STI they would burn my clutch a little or the car would die on them and I would charge them couple hundred for the clutch. My best was 13.306 in my STI I will see what I will do in IS when I receive it finally should be here beginning of June
Old 04-13-06, 02:07 AM
Mr.LS400
Mr.LS400's Avatar
what about the gear shifts in the IS350? does respond well as you shift up? i heard that you should release your foot from the gas pedal, shift up, and then step on it again. is that true?
jasonr
03-20-14 02:59 PM
braandon19
03-14-14 02:21 PM
KangstaxD
10-04-09 02:50 PM
Crazy Yoda
11-14-06 06:26 AM
Quick Reply: IS350 0-1/4 mile
