Drag newby, please help estimate 1/4 mile from 1/8 mile times
#31
I see. Here is another crazy idea then. To rap your JoeZ pipe in some sort of heat insulator. I know the metal vs plastic inlet pipe has been discussed before. But some sort of fiberglass insulator sure couldn't hurt. Even if it's just when your engine is idling on the line and producing allot of heat. It would prevent the pipe to get to hot and in return get cooled quicker after take off. Right?
I see you guys removing your engine covers. Is this only to allow the cool down of the engines between runs? According to Lexus these are for proper air flow in the engine compartment. Notice any difference with it on/off for you run?
#32
#33
Check out this thread on IS300.net. Click Here
In response to your question about wrapping or ceramic coating the pipe
Dasgalloway on is300.net
"When launching @ WOT the engine bay is quickly "blown out" and IATs quickly drop to numbers comparable to stock or the JoeZ. Same on the highway, the 6* cruising difference became much smaller as soon as you gunned it, with all intakes getting very similar temperature deltas.
Engine bay temps:
Plastic pipes retain less heat than metal pipes. The JoeZ showed higher surface temps than the OEM plastic piece, but only by a small margin (2-4 degrees). Not enough to affect air temps any noticable amount."
Engine bay temps:
#34
Good read. Thanks. Just my kind with hard facts and numbers. Where is the follow up with some dyno's and noise measurement he was talking about? Did some searches and couldn't find it.
#36
Ok here is my last not so original idea to improve 1/4 mile times. Removing the front engine cover. The side ones doesn't matter but since they have to go off before the front. It would allow more air into the intake. Instead of passing through two small vents.
Same as this picture (but without the Blitz).
![](https://www.clublexus.com/gallery/data/500/P81.jpg)
#37
#38
The last few times I hit the track I did it with the engine covers off including that front piece. I don't know if it helped or not, but by looking at the design I would think it would help somewhat. Another reason to pull all the engine covers is that it should help cool things down a bit in between runs.
#39
Here is where the air now can go through to get to the inlet snorkel.
But your right on the reduced air pressure in front of the radiator. The hood has a second horizontal rubber seal that sits down on this front panel right after the snorkel (you can see the dirt line in the first pic). Seems to also force the air through the snorkel and prevent it to go between the engine cover and hood.
Pros and cons on both setup. Hard to call isn't it?
#40
As for the cooling period, I think only by removing the center cover can help. As the other panels do not cover the engine itself.
#41
I'd say there is more performance benefit to removing these engine covers.
Pros: Shed a few lbs, engine can cool off more effectively between runs, more airflow towards the snorkel inlet, etc.
Cons: more noise, radiator may not get as much cooling, not as pretty but who cares when you are at the track.
I really can't say for sure if there is any gain or not to be had removing these pieces as my last few trips to the 1/4 mile I had them off.
#44
1 Post
if you remove that piece, your air snorkel will suck in hotter air than normal. That plastic piece act like a heat shield against the metal frame which gets hot. I have taken it off before and I can tell you it gets pretty hot.
