Drag Strip Discussion about Lexus straight line racing on the 1/4 mile, 1/8 mile and top speed flats.
track night with sc300 2jzgte very dissapointed
Old 09-11-11, 12:13 AM
preston145
preston145's Avatar
Default track night with sc300 2jzgte very dissapointed
Alright guys this was the first night I took the car out to the track out here in Charlotte NC. My car is a 92 sc300 2jzgte, map ecu 2, master power t70 are. 96. 16# spring. 93 pump gas, r154 trans with stock auto 4.27 diff. Very dissapointing times. Best was 8.7 at 90 MPH. I'm not new to the drag scene and I was not launching the car buy any means. I'm thinking the gears are just entirely to short. I wad on my 275 40 18 street tires. And wasn't spinning bad. Though 2.3 60 foots were also terrible. What are you guys trapping and what could cause the extreme slow times? I expected more low 8 to high 7. I figured the 4.27 would actually benefit me. But not at all. First gear runs out immediately with no boost till last 200 rpm 2nd feels strong and third lags then strong. Just thought I'd share.
Old 09-11-11, 12:20 AM
sc300max
sc300max's Avatar
Try adding a 75 shot of nitrous for the low end, hooked up with a pressure switch. So when you hit like 7 or 8 lbs of boost it shuts off. That will help you a lot with the lag. How much power are you making? If you have some kind of power street tires suck for the track. Get yourself some ET Streets Mickey thompsons so you can make some nice times.
Old 09-11-11, 12:30 AM
GS FONZy
GS FONZy's Avatar
Your gear ratio is too tall, try 3.76's from the auto tt or even the 3.26 from the GS400, so you can build up full boost without running out of gear.
Old 09-11-11, 12:32 AM
SourLex
SourLex's Avatar
Get lsd off of supra?
Old 09-11-11, 12:58 AM
onejapman
onejapman's Avatar
ur turbo is to big, and if you trying to do drag time. go for a t67 size. borg warner s366 is what most supra guys use or a precision turbo
Old 09-11-11, 06:30 AM
boosting
boosting's Avatar
ill be posting up my drag times soon, and i have the pte6765. Onejapman is right, the turbo is too big with out the proper support to get it hauling.
Old 09-11-11, 07:08 AM
Han7
Han7's Avatar
Originally Posted by GS FONZy
Your gear ratio is too SHORT , try 3.76's from the auto tt or even the 3.26 from the GS400, so you can build up full boost without running out of gear.
Fixed
Msglength
Old 09-11-11, 07:18 AM
iridebmx
iridebmx's Avatar
sounds like you need a quick spool valve! why dont people buy these things?
Old 09-11-11, 07:52 AM
spoolxexo
spoolxexo's Avatar
Everyone in here is wrong.
2.3 60's are what is killing you.
Get the diff to turn both wheels, and get real tires. Voilah.
You spent too much time and money on the HP, you forgot to support that horsepower with suspension, diff, etc.
Btw a 7 in the 1/8th is like an 11 in the 1/4, get that thing to hook up!
Old 09-11-11, 08:11 AM
tavarish
tavarish's Avatar
You need a way better launch. Get an antilag box and some better tires and youre all set.
Old 09-11-11, 08:37 AM
preston145
preston145's Avatar
I have tanabe sustec pros. I didn't mess with the dampening control. I'm going to throw in this sc400 diff to help the gearing. Ill have to reasearch on this anti lag valve. I do have a 2 step but it'd be pointless to launch on an open diff. I felt it wheel hop when I went 2.2. Thanks for the input guys. Y'all are great. And power I'm not sure of my numbers. Probably high 400's I would assume.
Old 09-11-11, 08:38 AM
stockhatch
stockhatch's Avatar
Sticky tires, 2 step, and drive it like you stole it.
Old 09-11-11, 08:43 AM
97-SC300
97-SC300's Avatar
Definitely get an tt auto LSD... that should've been done long before you took your car on a track with that tranny.
Old 09-11-11, 09:12 AM
xspsi6
xspsi6's Avatar
Yup the 60ft is your problem as everything comes down to the 60ft so get that to a 1.8ish and you will see the results you are looking for.
Old 09-11-11, 09:14 AM
account2x
account2x's Avatar
Your gear ratio is too short, try 3.76's from the auto tt or even the 3.91 from the SC400, so you can build up full boost without running out of gear.
fixed 2x
3.26 would cripple him.
Quick Reply: track night with sc300 2jzgte very dissapointed
