Lowering Springs
Technically, the 94-96 are MCV10, but the physical dimensions of the 92-93 VCV10 should be identical. The first letter in the model code denotes the engine ("M" for 1MZ-FE and "V" for the older 3VZ-FE V6).
Originally posted by MCV20
just came up one more lowering springs in my mind since u metion your ride VCV 10 chassis early...
ESPELIR springs...
which lower F:40-45mm R:30-35
spring rate F:5.0 R:3.0
here is the spec and link:
http://www.passion-carnet.com/gt/esp...spelir_sus.htm
check out the VCV chassis..
ESPELIR springs...
