05 es330 starter?
7th Gear
05 es330 starter?
Hello everyone,
this started months ago although it stopped so I didn’t get to fix it.
From time to time my car won’t crank, although everything like the dash and radio will turn on even the AC. It happens randomly mostly but I noticed mainly when I turn the car off for about 5 minutes then attempt is when it occurs. I hear a click I was wondering if it could be my starter?
I also had an issue with my camshaft position sensor and I changed one of them months ago, although it turns out there’s two of them but one is hard to access and honestly I don’t know exactly where it’s at so I haven’t attempted. This issue started around the time my car stopped turning on randomly.
I understand I’m going two different directions, just asking what are good tips to check if it’s the starter and if its the position sensor if someone knows where the one for the bank in the back is?
Hello,
One trick to check if the starter is at fault was to hit it with the hammer while the key is in the Start position, vibration may jolt all the dust from the brushes and clogged bearings, as well as restoring lost contact, causing the starter to spin, if that's your case, you will need a new starter. You can also take it apart and look inside to make sure that it is the fault.
As for the Camshaft sensor, those tend to be quite robust, and it appears that you did replace the right one as Bank to is closer to the Radiator on that car. It may be that you are affected by the TSB you listed, and you may have to look for a new ECU, which shouldn't be too expensive for those cars. Try resetting the code by disconnecting the battery for a few minutes and see what happens..
Hope thus helps and best of luck!
7th Gear
Hello, thanks for the reply and I actually took the car to the Lexus dealership and t
Hello,
barrynwatt
01-04-14 08:25 PM
